Clutch switch
  • S54B32
    Bought a brown clutch switch on Ebay from MPartsWorldWide. Only one was available on all of ebay....and I paid handsomely for it.
    They pop up used from time to time but be prepared to pay 200-300 for it. Green may be the way to go as it's much cheaper but you will not get cruise control functionality (not sure if that matters to you). Brown clutch switch is the only way to get cruise control + fix all the issues you're reporting.
    Click image for larger version Name:	IMG_5257.jpg Views:	0 Size:	159.4 KB ID:	208889
    Sorry but that’s wrong. Only difference between brown and green is clutch interlock circuit for ews interlock in US and Japan E46 m3. So coding out clutch interlock in ews Modul will be enough with the green switch (that is made for EU M3).
    only black clutch switch will never work on the m3.
  • AWE46M3
  • maupineda
    I got mine (green) from thebmwmini online store
  • Theraqa
    Have same problem here, i ordered brown one from fcpeuro and received black one, contacted them to send me correct part but they still haven't send replacement...
    My throttle is on point but car does stall sometines when comming to stop, also cruise control is not working either
  • Jeastvold
    started a topic Clutch switch
    Clutch switch
    Hey guys,
    i bought a smg —> to 6 speed swapped E46 M3. The previous owner didn’t complete the swap and left it with no clutch switch so it has the throttle lag and randomly dies coming to a stop. Super annoying! Ive followed the DIY’s to wire up the car to be ready for the coding/clutch switch it needs but i cant find a place that has the brown or green switch! I’ve ordered part number 61319122700 (brown) and 61319122701 (green) and both came in as black (but still had the correct part numbers printed on them). I’ve read online these will not work unfortunately and was looking for some insight if anyone was able to the get the black switches to work? Ecuworx will be doing my coding. Personally i don’t care if cruise control never works… i just want my throttle response to come back and it to stop dying on me at idle.
    thanks!
