Hello!
I am new to this forum. We own a 2001 M3 E46. We're located in Spain.
I come to you since we are desperated after many checks without success. I cound not find any thread with this matter, so I create a new post.
The problem is that one day, when arriving to the garage to go for a drive with she, a high pitched and continuous sound was coming out of the car. The same noise of an alarm but continuous, not a beating one.
It happenned suddenly, without having made any mod or work in the car. One day we parked it in the garage and some days later it was "shouting". We do not know for how long it could have been that way, since we live about 15 minutes drive from the garage and go there every 1-2 weeks.
We though this scream should be the alarm, and checked for the fuses. Removed fuse 67 (which looked fine, by the way) and it stopped sounding. We replaced it by a new one, and the car started shouting again.
As per the fusecard, number 67 applies to alarm system, immobilizer and centre-mirror. Important to remark that our M3 does not have an immobilizer for a long time now (4 years roughly), which is previous to this happening, so this system was discarded.
With regard to the central mirror (only has the "red nose" and the darking option when light comes from cars behind; no rain, whipper or any other sensors), we disconnected its connector and plugged the fuse 67 again, and there it came the alarm immediately. So as of now, mirror got discarded. Should we had an additional mirror we would have tried to connect this to discard it with more guarantee.
So right now we are running without the said fuse number 67. But we would like to solve the matter so that the related systems work as they should.
I don't know if it could be related, but the remote openning/closing does not work since we removed the said fuse except from very time to time. Just in case this fact could help...
By the way, we replaced the battery and the alternator 2 years ago, and voltage is perfect. Whilst this poltergeist is happening for few months. And the hood-open switch is unabled on purpose too. In any case, the alarm would sound in beating mode (normal mode) and not as a continuous beep.
Did anyone have the same or similar happening? Any ideas what could be or anything else we could check?
Thanks a lot in advance for your time and help, and apologies for the long text (but I wanted to explain every detail and check we made).
Hope you can help us sort this out.
Kate
Kate
