If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Guys, which map or injector constant should i change if i go larger injectors? Any "easy" parameter change or i should correct all injector opening time maps?
