100% confirmed that the value exposed in TestO is AQ_REL. AQ_REL_ALPHA_N_PT_KORR is not exposed at all in TestO.
Okay - so I've categorically confirmed that the AQ_REL_ALPHA_N value which is used as the y axis in the CSL Alpha N map is NOT available over DS2. AQ_REL is available over DS2 as is AQ_REL_ALPHA_N_PT_KORR (on the DME side at least).
I'm 90% sure that it's AQ_REL that's exposed in TestO as "Relative Opening", which would make sense on pretty much every level, but I have a bit more work to go to be 100% confident in that.
Either way, it looks as though the VE tuning process can be made more accurate with the appropriate compensation for this.
I posted the below in the a quick and easy way to street tune your csl conversion for drivability thread, and thought I'd also put here for reference:
For what it's worth I've just been working through this in my disassembly project and thought it would be worth noting here. Below is a summary of how it comes together:
AQ_ABS (absolute cross-sectional opening) = AQ_ABS_LLS (absolute cross-sectional opening of idle control valve) + AQ_ABS_WDK (absolute cross-sectional opening of throttle plates)
AQ_REL (relative cross-sectional opening (%)) = (AQ_ABS - K_AQ_ABS_MIN (minimum possible cross-sectional opening)) / (K_QA_ABS_MAX (maximum possible cross-sectional opening) - K_AQ_ABS_MIN)
This AQ_REL value is what's used in the standard M3 software, a commonly referenced example of this is the VANOS maps - AQ_REL is the y-axis in those tables.
The important thing to know is that AQ_REL isn't used directly in the CSL AlphaN maps. It's actually a modified version of AQ_REL that is used.
For the purposes of this explanation I will call this modified value AQ_REL_ALPHA_N it is calculated thusly:
AQ_REL_ALPHA_N = AQ_REL / AQ_REL_ALPHA_N_FAKT
So what's AQ_REL_ALPHA_N_FAKT? It's just my name for the output of the lookup curve at: 0xE056
x axis is N (rpm) and the output is a scaling factor.
Essentially what this means is that AQ_REL_ALPHA_N will be a smaller value (between 0-30% smaller dependent on RPM) than actual AQ_REL beneath 2400 RPM.
Additionally there is another value that is also calculated in the same routine, let's call it AQ_REL_ALPHA_N_PT_KORR which is additionally scaled based on P_UMG (Ambient air pressure) and TAN (Intake air temperature).
This value isn't used in the CSL AlphaN maps (or in other operational code), but it is used in two routines which seem to be involved in the sending/export of data (I haven't figured out yet if these are the DS2 routines or something else). Crucially AQ_REL_ALPHA_N is NOT referenced in any sending/export routines. Which raises the possibility that the "Relative Opening" datapoint that we are logging in TestO isn't even the same data point that is actually used as an input to the VE table (indeed it could even be the standard AQ_REL variable). Looking at the two tables above they are normalized around 20 degrees C intake temp and ambient air pressure of 962mbar, so it's not going to be too far off either way, but for example today in Auckland was 1016mbar at 20C, so PRESUMING THIS IS THE CASE I'd be looking at a 4% variance.
I will spend more time looking at this to see if I can establish with certainty which of the two variables "Relative Opening" represents.
Also worth mentioning that the MAP sensor does not have any part in the calculation of AQ_REL. The MAP sensor is used in the calculation of air mass, which in turn is used in the calculation of final Relative Fill (an adjustment to the value obtained from the VE table).
I realize this post is more focused on the "academic" side but hopefully of use to the collective understanding.Last edited by karter16; 06-02-2025, 12:50 AM.
- Likes 4
Well being sick has given me the excuse to spend some more time working on the disassembly. I've been focused on the calculation of rg_m which is the mass of residual gas in the cylinder and is one of three components which results in the final calculation of mass of gas in the cylinder (which is key to the calculation of final RF).
I'm very pleased to have completely figured out the EVAN (intake cam) component of the calculation of rg_m. The position of the intake camshaft influences the amount of residual gas left in the cylinder. I've *almost* figured out the exhaust cam component of it as well, but am not quite there yet. I haven't yet figured out the units of the curves at 0xe6d6 and 0xe708 ( ppm008 if you're around I'd love a hint on these :-)).
Anyway - here's the intake component of the function. Once I've got the entire function figured out I'll do a write up and add it to the wiki page
I'm really pleased to have figured this out as MPowerE36's analysis hadn't gone in to this aspect of the mass calculation, and as far as I know no one has (publicly) figured this out.
- Likes 5
Me neither but it would be interesting to compare the VE tuning output from both with and without the MAP sensor tuning results.Originally posted by karter16 View PostToday I finally got round to trying setting k_rf_cfg to 0x02 (from 0x12) to take the MAP sensor out of the final RF calculation path.
The result is that the car behaves and drives in the same way as if the MAP sensor is physically disconnected. The car runs in AlphaN + TABG adjustment mode.
I didn't personally have any doubt that this would be the case (although I know others did), but good to prove this. I think I mentioned previously that it seems like this would be good practice to take the MAP sensor out of the RF calculation path when doing the VE tuning process. I can't think of an objective way to measure this though. If anyone has any ideas I'm all ears!
Yep less responsive part throttle and more jerkiness. Exactly the same effect as disconnecting (electrically) the MAP sensor and going for a drive.Originally posted by ac427 View Post
What difference did you notice with k_rf_cfg to 0x02, poor part throttle performance?
What difference did you notice with k_rf_cfg to 0x02, poor part throttle performance?Originally posted by karter16 View PostToday I finally got round to trying setting k_rf_cfg to 0x02 (from 0x12) to take the MAP sensor out of the final RF calculation path.
Continuing on with the MAP sensor work. I'll write this up properly and put it in the MAP sensor wiki, but for now here's the disassembled code listing. This is the function that takes the raw MAP sensor AD values from the ring buffer and calculates MAP pressure and manifold vacuum pressure.
It really would be very nice to have the actual parameter/variable names, but you'll have to suffer through my made up names (identified as all lowercase) :-)
Key things of note:
- The code loops through the ring buffer every time it runs and pulls and averages a number of valid samples (by default it's actually only 1 valid value that it samples).
- It then takes the raw value and offsets it and scales it according to the MAP scaler and offset parameters that have been known for some time.
- Manifold vacuum pressure is calculated as P_UMG (ambient pressure from the on-DME pressure sensor) minus MAP pressure.
- The function runs in both the segment task and the 10ms task.
- Likes 4
This one is interesting. This (function at 0x00011e3c) is a debug function that runs in the background task. It tracks the time in milliseconds since the function last run and captures the longest time in DB_TBGND_MAX and the average in DB_TBGND_AV. This would have been useful during development as the BMW engineers were adding to the codebase to monitor the system and make sure that the CPU was getting to the background task regularly enough.
- Likes 3
0x00ffeb36 is the 32 bit telegram from the MFL to the DME with the cruise control buttons status. This variable in turn is populated from the TPU config RAM (0x00ffff08) which is a shared RAM section between the DME and the TPU to allow transfer of data. The TPU facilitates the one-wire serial interface to the MFL.
Section 8.3.2 in 3.05 EGAS Safety Concept in the funktionsrahmen describes how this works and it seems that this is pretty much how it's implemented in the code as well. The safety concept code is really interesting to dig into and seems in general to be pretty close to how it's documented in the funktionsrahmen.
0x00ffe508 and 0x00ffe50a appear to be "total count of interrupts" and "number of interrupt service routines currently in progress" (note it is possible for this to be greater than 1 as a higher priority interrupt will "interrupt" a lower priority ISR) respectively.
I've named these "sys_interrupt_counter" and "sys_active_interrupts".
edit: renamed to sys_isr_count to mirror BMW's naming of CAN_ISR_COUNTLast edited by karter16; 03-29-2025, 10:32 PM.
If anyone has any info about these 4 curves it would be super useful to know. From the code I I've worked through so far I *think* that 0xe708 and 0xe732 respectively are possibly representing molar mass of the residual gas mix based on camshaft position, but not overly confident about that yet.
These are all of the parameters from the master binary which we currently don't have the actual names for. For anyone who's wondering the addresses below are as the prog binary references them, so the actual addresses in the partial would be the value below minus 0x80000. e.g. 00088826 would be 0x8826.00088826 00089840 00089a4c 0008a6c5 0008a97a 0008a97c 0008a97e 0008a9a2 0008a9a3 0008a9a4 0008a9a6 0008a9a8 0008a9aa 0008c354 0008c35a 0008c35c 0008c376 0008c378 0008c37a 0008c37b 0008c37c 0008c37e 0008c380 0008c382 0008c384 0008c3db 0008c558 0008c55a 0008c55c 0008c56c 0008c56e 0008c582 0008c59e 0008c5ba 0008c5e6 0008c682 0008d000 0008d002 0008d201 0008d202 0008d204 0008d205 0008d220 0008d222 0008d2ee 0008d2f0 0008d2f2 0008d2f4 0008d2f6 0008d2f8 0008d2fa 0008d2fc 0008d716 0008db30 0008df4a 0008dfac 0008e056 0008e088 0008e08a 0008e08c 0008e08d 0008e08e 0008e25c 0008e5e4 0008e5e8 0008e5ea 0008e5ec 0008e5ed 0008e5ee 0008e5f0 0008e5f2 0008e5fa 0008e5fc 0008e5fe 0008e600 0008e602 0008e604 0008e61e 0008e638 0008e69a 0008e69c 0008e69e 0008e6a0 0008e6a2 0008e6a4 0008e6c6 0008e6ce 0008e6d0 0008e6d2 0008e6d4 0008e6d6 0008e708 0008e732 0008e764 0008e7ae 0008e8fe 0008e918 0008e91a
And these are all the parameters from the slave binary which we currently don't have actual names for. I've included all the SMG parameters (0008a8xx to 0008aexx) which are missing actual names as well. Not sure if anyone has those, but thought I'd include them for completeness. To convert the below addresses to the offset in the partial it's what's below minus 0x88000. e.g. 0008808a would be 0x008a.0008808a 0008903f 0008a1da 0008a1dc 0008a1de 0008a1df 0008a1e0 0008a1e2 0008a1e4 0008a1fa 0008a1fc 0008a1fe 0008a200 0008a202 0008a204 0008a206 0008a228 0008a24a 0008a24c 0008a24e 0008a251 0008a252 0008a253 0008a254 0008a255 0008a256 0008a258 0008a259 0008a25a 0008a25c 0008a25e 0008a260 0008a262 0008a263 0008a264 0008a265 0008a80e 0008a811 0008a814 0008a816 0008a817 0008a818 0008a819 0008a81a 0008a81b 0008a81c 0008a81e 0008a821 0008a824 0008a826 0008a82a 0008a82c 0008a830 0008a832 0008a838 0008a83c 0008a83d 0008a840 0008a842 0008a844 0008a846 0008a848 0008a84a 0008a84c 0008a850 0008a852 0008a853 0008a856 0008a85a 0008a85e 0008a860 0008a862 0008a865 0008a866 0008a867 0008a883 0008a88a 0008a88c 0008a88d 0008a896 0008a898 0008a89c 0008a89d 0008a8a2 0008a8b8 0008a8ba 0008a8c4 0008a8d4 0008a8e2 0008a918 0008a96e 0008a9a0 0008a9aa 0008a9b4 0008a9be 0008a9cc 0008a9da 0008aa30 0008aa44 0008aa52 0008aad2 0008aadc 0008aae4 0008aeb4 0008e706 0008e707
ppm008 really appreciate your help - any chance I could list out all the parameter addresses I'm working on and see if you've got details for any others? I've come up with names for a bunch but if it's possible to confirm the actual names that would be even more ideal. (don't want to bug you too much though so feel free to say no!)
