  • karter16
    0x00ffeb36 is the 32 bit telegram from the MFL to the DME with the cruise control buttons status. This variable in turn is populated from the TPU config RAM (0x00ffff08) which is a shared RAM section between the DME and the TPU to allow transfer of data. The TPU facilitates the one-wire serial interface to the MFL.
    Section 8.3.2 in 3.05 EGAS Safety Concept in the funktionsrahmen describes how this works and it seems that this is pretty much how it's implemented in the code as well. The safety concept code is really interesting to dig into and seems in general to be pretty close to how it's documented in the funktionsrahmen.
  • karter16
    0x00ffe508 and 0x00ffe50a appear to be "total count of interrupts" and "number of interrupt service routines currently in progress" (note it is possible for this to be greater than 1 as a higher priority interrupt will "interrupt" a lower priority ISR) respectively.
    I've named these "sys_interrupt_counter" and "sys_active_interrupts".
    edit: renamed to sys_isr_count to mirror BMW's naming of CAN_ISR_COUNT
  • karter16
    If anyone has any info about these 4 curves it would be super useful to know. From the code I I've worked through so far I *think* that 0xe708 and 0xe732 respectively are possibly representing molar mass of the residual gas mix based on camshaft position, but not overly confident about that yet.
Name:	Screenshot 2025-03-23 at 7.54.58 AM.png
  • karter16
    These are all of the parameters from the master binary which we currently don't have the actual names for. For anyone who's wondering the addresses below are as the prog binary references them, so the actual addresses in the partial would be the value below minus 0x80000. e.g. 00088826 would be 0x8826.
    00088826
    00089840
    00089a4c
    0008a6c5
    0008a97a
    0008a97c
    0008a97e
    0008a9a2
    0008a9a3
    0008a9a4
    0008a9a6
    0008a9a8
    0008a9aa
    0008c354
    0008c35a
    0008c35c
    0008c376
    0008c378
    0008c37a
    0008c37b
    0008c37c
    0008c37e
    0008c380
    0008c382
    0008c384
    0008c3db
    0008c558
    0008c55a
    0008c55c
    0008c56c
    0008c56e
    0008c582
    0008c59e
    0008c5ba
    0008c5e6
    0008c682
    0008d000
    0008d002
    0008d201
    0008d202
    0008d204
    0008d205
    0008d220
    0008d222
    0008d2ee
    0008d2f0
    0008d2f2
    0008d2f4
    0008d2f6
    0008d2f8
    0008d2fa
    0008d2fc
    0008d716
    0008db30
    0008df4a
    0008dfac
    0008e056
    0008e088
    0008e08a
    0008e08c
    0008e08d
    0008e08e
    0008e25c
    0008e5e4
    0008e5e8
    0008e5ea
    0008e5ec
    0008e5ed
    0008e5ee
    0008e5f0
    0008e5f2
    0008e5fa
    0008e5fc
    0008e5fe
    0008e600
    0008e602
    0008e604
    0008e61e
    0008e638
    0008e69a
    0008e69c
    0008e69e
    0008e6a0
    0008e6a2
    0008e6a4
    0008e6c6
    0008e6ce
    0008e6d0
    0008e6d2
    0008e6d4
    0008e6d6
    0008e708
    0008e732
    0008e764
    0008e7ae
    0008e8fe
    0008e918
    0008e91a
    And these are all the parameters from the slave binary which we currently don't have actual names for. I've included all the SMG parameters (0008a8xx to 0008aexx) which are missing actual names as well. Not sure if anyone has those, but thought I'd include them for completeness. To convert the below addresses to the offset in the partial it's what's below minus 0x88000. e.g. 0008808a would be 0x008a.
    0008808a
    0008903f
    0008a1da
    0008a1dc
    0008a1de
    0008a1df
    0008a1e0
    0008a1e2
    0008a1e4
    0008a1fa
    0008a1fc
    0008a1fe
    0008a200
    0008a202
    0008a204
    0008a206
    0008a228
    0008a24a
    0008a24c
    0008a24e
    0008a251
    0008a252
    0008a253
    0008a254
    0008a255
    0008a256
    0008a258
    0008a259
    0008a25a
    0008a25c
    0008a25e
    0008a260
    0008a262
    0008a263
    0008a264
    0008a265
    0008a80e
    0008a811
    0008a814
    0008a816
    0008a817
    0008a818
    0008a819
    0008a81a
    0008a81b
    0008a81c
    0008a81e
    0008a821
    0008a824
    0008a826
    0008a82a
    0008a82c
    0008a830
    0008a832
    0008a838
    0008a83c
    0008a83d
    0008a840
    0008a842
    0008a844
    0008a846
    0008a848
    0008a84a
    0008a84c
    0008a850
    0008a852
    0008a853
    0008a856
    0008a85a
    0008a85e
    0008a860
    0008a862
    0008a865
    0008a866
    0008a867
    0008a883
    0008a88a
    0008a88c
    0008a88d
    0008a896
    0008a898
    0008a89c
    0008a89d
    0008a8a2
    0008a8b8
    0008a8ba
    0008a8c4
    0008a8d4
    0008a8e2
    0008a918
    0008a96e
    0008a9a0
    0008a9aa
    0008a9b4
    0008a9be
    0008a9cc
    0008a9da
    0008aa30
    0008aa44
    0008aa52
    0008aad2
    0008aadc
    0008aae4
    0008aeb4
    0008e706
    0008e707
  • karter16
    ppm008 really appreciate your help - any chance I could list out all the parameter addresses I'm working on and see if you've got details for any others? I've come up with names for a bunch but if it's possible to confirm the actual names that would be even more ideal. (don't want to bug you too much though so feel free to say no!)
  • karter16
    Originally posted by ppm008 View Post
    8a980 KL_TANM_PT1_INIT
    8e5f4 K_RF_DIAG_F_KATH
    8e5f6 K_RF_DIAG_F_VAN
    8e5f8 K_RF_DIAG_SCHWELLE
    8e848 KF_RF_KORR_DRREL
    8e6c8 K_RG_R
    8e6ca K_RG_V_HUB
    8e6cc K_RG_ZYLANZ_BANK
    Amazing - thank you so so much!
  • ppm008
    8e6c8 K_RG_R
    8e6ca K_RG_V_HUB
  • ac427
    I'm continuing to make good progress. I've now understood and named about 70 of the 112-odd CSL specific parameters. The names are of course my best guess as to what they would logically be named based on what I can figure out from BMW's naming convention. Unless anyone who has access to the actual names of these parameters is willing to share then my made-up names will have to do :-)
    There's about 40 more parameters which I'm still working through to establish their purpose and what they should be called, but I'm very pleased with how it's going. I'm categorizing as I go (as can be seen in the screenshot below), which shows the modules which contain changes for 0401.
    Great work as always mate.
  • karter16
Name:	Screenshot 2025-03-20 at 9.47.07 PM.png
  • karter16
    I've renamed the function "calculate_pressure_from_air_mass()" in my previous post to "p_egbp_calc()" given, as I've been working through everything, I've identified that this function is looking up a value for exhaust gas back pressure.
    This is the function with parameter and variable names that make sense:
Name:	Screenshot 2025-03-14 at 6.15.12 PM.png
    The function looks up a curve which provides an estimated value of exhaust gas back pressure based on current ML (air mass flow).
    This value is relative (e.g. it's just the back pressure component). so this is then added to P_UMG_FILTER (ambient air pressure) to get an absolute exhaust gas back pressure measurement.
    This value is filtered through a PT1 filter and then checked for max/min values for plausibility, before returning.
    Here's what the parameters look like:
Name:	Screenshot 2025-03-14 at 6.18.02 PM.png
    The calculated value p_egbp is then used in the calculation of rg_m.
  • karter16
    I haven't posted any updates in a few days but have been making some progress.
    One of the key components of MpowerE36's work is the calculation of what he terms m_720_map, which is the calculated air mass per 720 degrees of crankshaft rotation. It's the main component of the calculation of RF from MAP.
    as he identifies the calculation of m_720_map looks like this:
    Code:
    m_720_map = m_720_1 - m_720_2 - m_720_3
    Now m_720_1 is calculated air mass based on the MAP sensor reading and nominal air pressure and temperature - that's the baseline if you will.
    m_720_2 is a compensation for pressure loss in the system (due to TETV (tank ventilation) and the like).
    m_720_3 Mpower_E36 has identified as "air mass correction per 720 degrees of crankshaft rotation" and referred to the table at 0xe42c - it looks like this:
Name:	Screenshot 2025-03-14 at 8.52.59 AM.png
    Now the thing is, by default 0401 doesn't use this table. If we look at the segment task we see (in part):
Name:	Screenshot 2025-03-14 at 8.54.08 AM.png
    k_rg_m_cfg's (my name) value is 1 in 0401:
Name:	Screenshot 2025-03-14 at 8.55.03 AM.png
    So by default two functions are called. the second of these (what I've called rg_m_calc()) provides a calculated value for MpowerE36's m_720_3.
    And when I look through this function it is calculating a mass value based on things like intake and exhaust camshaft position, tabg (there are an entire separate set of tabg calculation functions solely for informing this function), etc.
    Now why would we need to know camshaft position and exhaust gas temperature? Because what m_720_3 is is the calculation of the mass of residual exhaust gas left in the cylinder (which varies, especially, based on cam overlap). Remember the DME intentionally recirculates some exhaust gas (particularly at certain RPM and loads) to reduce emissions and we can see this playing out in the table above (which isn't used by default, but gives us a representation of what the system is doing).
    Anyway - I have some more work to do to finish up documenting the interpretation of this function, but pleased to have figured this out and have a more concrete understanding of exactly what it is.
  • karter16
    Originally posted by sda2 View Post
    Awesome work! Its nice to see more people diving into this. I have some IDA disassemblies of MSS54 from the CAN bus analysis, I dig them out and send them to you, maybe its of use for you.
    Would you be fine with me linking this thread or the Github page on MS4X.net?
    That would be awesome thanks! The more we share the better! Yes please feel free to link to either or!
  • sda2
  • karter16
    Originally posted by SliM3 View Post
    Don't rely too heavily on that funktionsrahmen as it is not accurate!
    Yeah definitely - it's riddled with inaccuracies/additions that have been made in code after that version of the funktionsrahmen was written. Have found it useful though to explain some of the concepts / thinking behind various modules that you can then match up (or not) to what's in the code.
  • SliM3
    Hey - it's a short doc but 8.02 in the funktionsrahmen explains it https://github.com/karter16/CSL_0401...mic%20Lead.pdf
    Essentially RF can be adjusted for knock protection or cylinder pressure management. The integral component is suspended while this is in effect, so that it doesn't try to “adjust out” the dynamic adjustment.
