  • ac427
    My data logs show that if you actually duct the lower snorkel to the bumper, you will have low IATs above 40mph. My theory is that the open top half of the flap actually allows air exchange, functioning as an exhaust when the lower half is supply. Just a guess based on my data logs with flap open/closed.
    Also, it’s not just the IAT that’s right behind the radiator, but also the thermally conductive airbox itself (carbon should be a lot more conductive than plastic). Hot airbox could mean hot air at low speeds and loads, so it’s my opinion that the IAT is conservatively placed to prevent damage to the engine. If you’re concerned about the IAT readings, you’re WAY better off just ducting from the bumper to the airbox and actually having low IATs vs trying to spoof lower temps. I’ll get off the soap box now.
    All good mate and thank you for the explanation.
    yeah echoing this. I've had a look through 0401 and 1801. TAN is calculated exactly the same in both (e.g. there's no adjustment to the calculation of TAN itself in 0401), the KLs and KFs that take TAN as an input are also the same between both. The only difference is 0401 has additional code to utilize TAN in the calculation of RF based on MAP sensor and TAN. However as MpowerE36 has shown, the code implementation of the maths doesn't include any sort of "adjustment factor". Which further supports Bry5on's comment above. I think we can conclude doing it the way BMW did is a conservative approach. I would think as soon as you get some reasonable airflow through the box the IAT will be fairly accurate, and when you are sitting still (which isn't really the point of a CSL in BMW's eyes remember) the heat soak resultas in a conservative reading.
    Thank you both for you help. It's really good to gain an understanding of not only how it works but the thinking behind it.​
  • karter16
    yeah echoing this. I've had a look through 0401 and 1801. TAN is calculated exactly the same in both (e.g. there's no adjustment to the calculation of TAN itself in 0401), the KLs and KFs that take TAN as an input are also the same between both. The only difference is 0401 has additional code to utilize TAN in the calculation of RF based on MAP sensor and TAN. However as MpowerE36 has shown, the code implementation of the maths doesn't include any sort of "adjustment factor". Which further supports Bry5on's comment above. I think we can conclude doing it the way BMW did is a conservative approach. I would think (edit: actually as Bryson has proven) as soon as you get some reasonable airflow through the box the IAT will be fairly accurate, and when you are sitting still (which isn't really the point of a CSL in BMW's eyes remember) the heat soak resultas in a conservative reading.
  • Bry5on
    No worries. It would certainly be an interesting experiment.
    Speaking of calibration, it would be interesting to know how the CSL IAT is coded for the heat soak issue. I mean, BMW could have placed it anywhere but they put it in a place where its output is bound to be skewed by the heat from the engine. Obviously they accounted for this in coding but i wonder if there is a point the output from the IAT just becomes useless?
  • Slideways
    Both the MAF and the CSL IAT need to be behind the filter to prevent damage to the sensor. The MAF even needs a mesh screen in front of it, my guess is to improve airflow over the sensor.
    BMW used that IAT for a reason; otherwise, they could have used the other style sensor from their older models.
  • ac427
    Not a lot of losses at part throttle, which is where this would be most useful I think. Then tune WOT without the HFM by AFR and open the flap, redo AFR for the flap open case. All the acronyms, sorry!
  • karter16
    What year did the E46 M3 GTR come out?
    It was a V8. I'm not sure which ECU it used though.
    Also, which DME did the E39 M5 have, probably a previous generation MSS5x ECU.
    GTR was 2001 I think, so before the CSL. The DME in the race version was entirely separate, not sure what they did in the strassenversion but suspect it would have been a derivative of that.
    The E39 M5 was the MSS52.
  • Bry5on
    True, I guess you could mount a MAF anywhere near the actual air intake path and then calibrate for loses?
  • ac427
    Easy enough to make an adapter for the non-CSL MAF to the lower snorkel, then just leave the flap closed.
  • Bry5on
    Are MAF's available in the CSL snorkel diameter?
    It would interesting to implement an MAF for part throttle quality research.
    Apologies, i could have put these these as one post but i was using the phone on the train home.
  • ac427
  • ac427
  • karter16
    karter16
    Is there anything that would suggest BMW used some of the code to develop the one-off E46 M3 CSL V8? I think that Terra said that the MSS54/HP has spots on the circuit board to drive two extra cylinders. Also, the S62 did run on MAFs.
    Click image for larger version  Name:	6be625c603ea7802677d0e9057b52a4a.png Views:	4 Size:	565.4 KB ID:	296837
    I can't say for sure but all the code I've seen is capable of handling 8 cylinders (eg all the TZ and TI arrays are for 8 cyl etc), plus has 2x HFM A/D converters. Standard M3 just uses HFM1 (pin 1 on X60003), HFM2 is pin 18 and 0401 uses this for the MAP sensor and HFM1 for flap pot. As it stands 0401 as is wouldn't run it because HFM2 is assumed to be MAP sensor, but certainly could have been a derivative I would imagine.
    Pretty sure a lot of the code is fairly common across MSS54 and MSS52, plus funktionsrahmen suggests at least some fmodules are ported to/from MSS60 project.
    Edit: to be clear, MSS54 software in general has provision for 8 cylinders, which I presume is due to similarity with MSS52 software.
  • 0-60motorsports
    karter16
    Dream E46 M3 right there and it was SMG too. LOVE IT!
  • Slideways
    karter16
  • karter16
    I'll bet they tuned the car with an HFM in the loop at some point to get the cam baselines
    Good call - that makes a lot of sense.
