I have an S54 swapped E36. Swapped it last year.
Stock S54, MSS54HP, K&N intake, ZF gearbox etc.
Software version 2001-JD34
I am no stranger to mapping/coding cars, as i had a M52 turbo car before that i tuned using Romraider on MS41.3.
for the swap I used the info from the MSS54 wiki page and the how to video's from R3Z3N on youtube.
all was fine, at least I thought.
Yesterday I had my anual "smog", and the car passed. but what I noticed was that my AFR's where off. today i logged with BMWlogger.
I noticed that my O2's are extremely negative (pulling a lot of fuel) during idle. about 25%. During normal operation they seem to be ok... not perfect but ok.
overall they are pulling fuel. I decided to check my tune. I 0'ed out the "SAP engine to coolant temp factor" hoping that might solve the rich Idle.
I started over with the all original Bin, followed R3Z3N's how to again (patch SAP/Cat heating etc.)
I set the RPM limiter to 8100 in dyno mode en set both master and slave to 02 (Role).
Welp, no change in the rich Idle.
And RPM limit was still at 6300.
Did a readback, and my changes did stick to the ECU.
I'm lost. Can someone point me in the right direction?
Am i missing something?
