What is the best and easiest way to code out the daytime running lights on my E46?
Best way to code out Daytime running lights
NCSexpert + NCSdummy, PA soft, or other subscription model ones like iCarly, bimmercode
Here's a quick rundown of how to use NCSexpert & NCSdummy from Gemini:
For Angel Eyes (Halos) as DRLs
If your car has factory-fitted "angel eyes" or you have retrofitted them, use these parameters to make them your DRLs.- GEDIMMT_FL_ALS_DRL: Change from nicht_aktiv (inactive) to aktiv (active). This dims the front turn signal bulbs to act as DRLs.
- GED_FL_ALS_DRL: This parameter may also be labeled this way, depending on your car's model and production date.
- DAUERFAHRLICHT_US: Change from aktiv to nicht_aktiv. On Canadian-spec cars, this disables the default DRL setting, which illuminates the main headlights.
- PO_ALS_DRL: Change from aktiv to nicht_aktiv. This disables the parking lights from being used as DRLs.
This is a standard option for some E-series models where the high beams operate at a reduced intensity for DRL functionality.- FL_DIMMUNG_ALS_DRL: Set to a specific value, usually wert_01 or wert_02. This adjusts the brightness level of the high beams when used as DRLs. The available values may vary by vehicle.
- Read your ALSZ module with NCS Expert.
- Connect your coding cable (e.g., K+DCAN) to the car and your laptop.
- Open NCS Expert, load a profile like Expertmode or FSW PSW MAN, and select your car's chassis.
- Select the ALSZ module (Process ECU > ALSZ).
- Choose the CODIERDATEN_LESEN job to read the module's data.
- This generates a trace file (FSW_PSW.TRC) in your WORK folder.
- Edit the trace file with NCS Dummy.
- Open NCS Dummy and load your FSW_PSW.TRC file.
- Find the DRL-related functions based on the list above. NCS Dummy translates the German coding language for easier editing.
- Change the parameters to your desired aktiv or nicht_aktiv values.
- Click "Export FSW_PSW" to save your changes to a new file, usually named FSW_PSW.MAN.
- Write the new coding back to the car with NCS Expert.
- Return to NCS Expert.
- Select the ALSZ module again.
- Choose the SG_CODIEREN job to write the new settings.
- Execute the job and wait for the coding to finish.
- Likes 2
