  • heinzboehmer
    Originally posted by kaiv View Post
    Very cool!
    Any chance you could whip up something for VANOS adaptions reset in INPA? It's a bit a chore to have to fire up DIS for every Vanos rebuild.
    This tool is even faster than INPA
    As per the title I've just put together a new utility for you guys that can do a few basics on the DME. Click image for larger version Name: DME_Utility-Release.png Views: 0 Size: 30.8 KB ID: 20329 Click image for larger version Name: DME_Utility-Release-Codes.png Views: 0 Size: 17.7 KB ID: 20330 The software can be used
  • kaiv
    Originally posted by Tomba View Post
    Unzip the attachment,
    place it in C:\EDIABAS\ECU
    start Tool32
    Click the 2nd [OPEN] icon
    open MSS54_VANOS_Test.tst
    Press F8 to run all tests
    A result screen similar to the quoted code text below should appear *tested only with bench set up! Not with a running engine
    Code:
    Test file : C:\EDIABAS\ECU\MSS54_VANOS_TESTS.TST
    Start : 18.06.2020 19:57:00.5
    Nr 1( 1) : 18.06.2020 19:57:00.6
    apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG", "","")
    JOB_STATUS = OKAY
    EVAN_ISTWERT = 60 00 3C .<
    EVAN_SOLLWERT = 52 00 34 .4
    EVAN_ISTWERT_EINH = Grad KW
    EVAN_SOLLWERT_EINH = Grad KW
    Nr 2( 1) : 18.06.2020 19:57:06.0
    apiJob("mss54ds0","STEUERN_EVANOS1_SPAETANSCHLAG", "","")
    JOB_STATUS = OKAY
    Nr 3( 1) : 18.06.2020 19:57:11.3
    apiJob("mss54ds0","STEUERN_EVANOS1_VERSTELLZEIT"," ","")
    JOB_STATUS = OKAY
    EVAN_VERSTELLZEIT_FRUEH = 0 00 00 ..
    EVAN_VERSTELLZEIT_SPAET = 0 00 00 ..
    EVAN_VERSTELLZEIT_FRUEH_EINH = ms
    EVAN_VERSTELLZEIT_SPAET_EINH = ms
    Nr 4( 1) : 18.06.2020 19:57:17.5
    apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT",""," ")
    JOB_STATUS = OKAY
    EVAN_STATUS = EVANOS-1-Einheit vorzeitig weggedriftet
    Nr 5( 1) : 18.06.2020 19:57:32.0
    apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG", "","")
    JOB_STATUS = OKAY
    AVAN_ISTWERT = 0 00 00 ..
    AVAN_SOLLWERT = 0 00 00 ..
    AVAN_ISTWERT_EINH = Grad KW
    AVAN_SOLLWERT_EINH = Grad KW
    Nr 6( 1) : 18.06.2020 19:57:37.3
    apiJob("mss54ds0","STEUERN_AVANOS1_SPAETANSCHLAG", "","")
    JOB_STATUS = OKAY
    Nr 7( 1) : 18.06.2020 19:57:42.5
    apiJob("mss54ds0","STEUERN_AVANOS1_VERSTELLZEIT"," ","")
    JOB_STATUS = OKAY
    AVAN_VERSTELLZEIT_FRUEH = 0 00 00 ..
    AVAN_VERSTELLZEIT_SPAET = 0 00 00 ..
    AVAN_VERSTELLZEIT_FRUEH_EINH = ms
    AVAN_VERSTELLZEIT_SPAET_EINH = ms
    Nr 8( 1) : 18.06.2020 19:57:48.9
    apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT",""," ")
    JOB_STATUS = OKAY
    AVAN_STATUS = AVANOS-1-Einheit vorzeitig weggedriftet
    Stop : 18.06.2020 19:58:03.3
    Dauer : 62.9 s
    Very cool!
  • Tomba
    Originally posted by jpy1980 View Post
    I had a p0011 and p0014.
    These are camshaft position sensors. Once these don't work, the VANOS test won't work.
  • jpy1980
    Your desired values our out of specification which is very weird!
    Any error codes?
    Hello!
    I had a p0011 and p0014. Then I changed my solenoid pack, cleaned the valve body and changed the o rings. After that I was getting a p0012 code but my p0011 and p0014 disappeared. Also my car would not stay on as it would die when coming to a stop.
    ended up getting the car towed to a shop. We will see what they say.
  • Tomba
    Any error codes?
  • oceansize
    Can't interpret from this, your output is missing required information (solenoid coil pack has likely failed).
  • jpy1980
    Hey guys im having issues with my car and I was told to run this test. Any feedback is appreciated. Thanks!
    Start : 29.04.2024 19:15:36.2
    Nr 1( 1) : 29.04.2024 19:15:36.3
    JOB_STATUS = OKAY
    EVAN_ISTWERT = 59 00 3B .;
    Nr 2( 1) : 29.04.2024 19:15:41.7
    JOB_STATUS = OKAY
    Nr 3( 1) : 29.04.2024 19:15:47.0
    JOB_STATUS = OKAY
    Nr 4( 1) : 29.04.2024 19:15:53.3
    JOB_STATUS = OKAY
    Nr 5( 1) : 29.04.2024 19:16:07.7
    JOB_STATUS = OKAY
    AVAN_ISTWERT = 48 00 30 .0
    AVAN_SOLLWERT = 20 00 14 ..
    Nr 6( 1) : 29.04.2024 19:16:13.0
    JOB_STATUS = OKAY
    AVAN_ISTWERT = 49 00 31 .1
    Nr 7( 1) : 29.04.2024 19:16:18.3
    JOB_STATUS = OKAY
    Nr 8( 1) : 29.04.2024 19:16:24.6
    JOB_STATUS = OKAY
    Stop : 29.04.2024 19:16:39.7
    Dauer : 63.5 s
  • BMWfanz
    Originally posted by inlinesix123 View Post
    Hi everyone, big thanks to Tomba for putting this test together.
    Is there anyone here who can check my results? Im chasing some vague vanos codes when running the car hard.
    JOB_STATUS = OKAY
    EVAN_ISTWERT = -2 FF FF FF FE ÿÿÿþ
    EVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö
    Nr 2( 1) : 19.01.2024 19:56:51.5
    JOB_STATUS = OKAY
    EVAN_ISTWERT = 57 00 39 .9
    EVAN_SOLLWERT = 75 00 4B .K
    Nr 3( 1) : 19.01.2024 19:56:56.9
    JOB_STATUS = OKAY
    EVAN_VERSTELLZEIT_FRUEH = 229 00 E5 .å
    EVAN_VERSTELLZEIT_SPAET = 212 00 D4 .Ô
    Nr 4( 1) : 19.01.2024 19:57:03.4
    JOB_STATUS = OKAY
    Nr 5( 1) : 19.01.2024 19:57:17.8
    JOB_STATUS = OKAY
    AVAN_SOLLWERT = -10 FF FF FF F6 ÿÿÿö
    Nr 6( 1) : 19.01.2024 19:57:23.1
    JOB_STATUS = OKAY
    AVAN_ISTWERT = 47 00 2F ./
    AVAN_SOLLWERT = 55 00 37 .7
    Nr 7( 1) : 19.01.2024 19:57:28.4
    JOB_STATUS = OKAY
    AVAN_VERSTELLZEIT_FRUEH = 193 00 C1 .Á
    AVAN_VERSTELLZEIT_SPAET = 190 00 BE .¾
    Nr 8( 1) : 19.01.2024 19:57:34.8
    JOB_STATUS = OKAY
    Stop : 19.01.2024 19:57:49.7
    Dauer : 63.8 s
    Hi! Intake camshaft is out of spec on 2 degrees but here shouldnt be any issues, but it not work in full 60 degrees, 59 only, same with exhaust- position is good but 47 degrees, should be 48. Reaction time is good!
  • inlinesix123
    JOB_STATUS = OKAY
    JOB_STATUS = OKAY
    JOB_STATUS = OKAY
    JOB_STATUS = OKAY
    JOB_STATUS = OKAY
    JOB_STATUS = OKAY
    JOB_STATUS = OKAY
    JOB_STATUS = OKAY
    Dauer : 63.8 s
  • Adam_
    I ran those two tests, FRUEHANSCHLAG (early stop?) then DICHTHEIT (leak test) on a warm engine.
    Intake and exhaust both gave status "Messung beendet, Soll-/Istwert-Vergleich ausfuehren" ("Measurement finished, carry out setpoint/actual value comparison") and setpoint and actual are within 5 degrees, so it seems leak/drift is okay!
    Here are my results:
    Code:
    Test file : C:\EDIABAS\ECU\MSS54_VANOS_LEAKTESTS.TST
    Start     : 06.10.2023 11:55:06.8
    Nr 1(  1) : 06.10.2023 11:55:06.9
    apiJob("mss54ds0","STEUERN_EVANOS1_FRUEHANSCHLAG","","")
      JOB_STATUS                      = OKAY
      EVAN_ISTWERT                    = 0                  00 00  ..
    Nr 2(  1) : 06.10.2023 11:55:12.4
    apiJob("mss54ds0","STEUERN_EVANOS1_DICHTHEIT","","")
      JOB_STATUS                      = OKAY
      EVAN_STATUS                     = Messung beendet, Soll-/Istwert-Vergleich ausfuehren
      EVAN_ISTWERT                    = 48                 00 30  .0
      EVAN_SOLLWERT                   = 45                 00 2D  .-
    Nr 3(  1) : 06.10.2023 11:55:27.0
    apiJob("mss54ds0","STEUERN_AVANOS1_FRUEHANSCHLAG","","")
      JOB_STATUS                      = OKAY
    Nr 4(  1) : 06.10.2023 11:55:32.3
    apiJob("mss54ds0","STEUERN_AVANOS1_DICHTHEIT","","")
      JOB_STATUS                      = OKAY
      AVAN_STATUS                     = Messung beendet, Soll-/Istwert-Vergleich ausfuehren
      AVAN_ISTWERT                    = 17                 00 11  ..
      AVAN_SOLLWERT                   = 15                 00 0F  ..
    Stop      : 06.10.2023 11:55:47.9
    Dauer     : 41.1 s
    It's pretty straight forward, but in case anyone needs it I added a test file, just like with the other one, unzip it and place it in C:\EDIABAS\Ecu
    The contents are exactly what Tomba recommended, but for both intake and exhaust.
    Code:
    1|mss54ds0|STEUERN_EVANOS1_FRUEHANSCHLAG
    1|mss54ds0|STEUERN_EVANOS1_DICHTHEIT
    1|mss54ds0|STEUERN_AVANOS1_FRUEHANSCHLAG
    1|mss54ds0|STEUERN_AVANOS1_DICHTHEIT​
    Thanks again Tomba!
  • Tomba
    The dichtheid test, I already posted my suspicion on this. Maybe it needs to be set differently. I do had a few cars in the past who succeeded the test flawlessly. Newer ECUs have the ability to show the actual measured values during such tests. For the MSS54 I haven't found it yet.
    Before the test the VANOS piston might need to move up (advance) then close both control valves (advance & retard) and observe the drift. A leak free system shouldn't drift to much. But I do suspect it is set correctly once the test it self is started.
    You can try the following,
    1. STEUERN_EVANOS1_FRUEHANSCHLAG and then,
    2. STEUERN_EVANOS1_DICHTHEIT
    Other option would be to activate the solenoids on your own with a separate device to advance with the engine speed lifted [STEUERN_LLS_TESTDREHZAHL] and then observe how the actual camshaft is moving once you don't activate them [STATUS_EVANOS1_IST] for intake, I would suggest TestO with DS2 Serial job for exhaust as I can't find the actual exhaust vanos position it in the job list.
    Numbers do look good in your result.
  • maupineda
    Yes, is a problem. Should not drift more than 5deg
  • Adam_
    Thanks Tomba for putting together the test file, it's super helpful. I couldn't get the VANOS tests in INPA since I have a K+DCAN cable and DIS didn't show VANOS tests, so your test file was perfect for me!
    I recently did a full VANOS rebuild using Beisan components (solenoid pack, all seals, pump disk, pressure regulator filter, cleaned vanos valve/manifold, etc) and ran the tests with a fully warmed up engine with 100 miles on it since the rebuild.
    Code:
    Start : 04.10.2023 13:26:00.3
    Nr 1( 1) : 04.10.2023 13:26:00.4
    JOB_STATUS = OKAY
    [EVAN_ISTWERT = 0 00 00 ..
    Nr 2( 1) : 04.10.2023 13:26:06.0
    JOB_STATUS = OKAY
    Nr 3( 1) : 04.10.2023 13:26:11.3
    JOB_STATUS = OKAY
    EVAN_VERSTELLZEIT_FRUEH = 209 00 D1 .Ñ
    EVAN_VERSTELLZEIT_SPAET = 221 00 DD .Ý
    Nr 4( 1) : 04.10.2023 13:26:17.9
    JOB_STATUS = OKAY
    Nr 5( 1) : 04.10.2023 13:26:32.6
    JOB_STATUS = OKAY
    Nr 6( 1) : 04.10.2023 13:26:38.1
    JOB_STATUS = OKAY
    Nr 7( 1) : 04.10.2023 13:26:43.5
    JOB_STATUS = OKAY
    AVAN_VERSTELLZEIT_FRUEH = 167 00 A7 .§
    Nr 8( 1) : 04.10.2023 13:26:50.1
    JOB_STATUS = OKAY
    Stop : 04.10.2023 13:27:05.1
    Dauer : 64.9 s
    It looks like angles and reaction time look good. I did rerun it and the intake showed 60 instead of 59; either way, it doesn't seem concerning. I actually had a hard time with timing the intake. It kept being off a little bit, but sapote had some great advice and discussion on another thread on how to get it shored up. So also, thank you sapote!
    The only thing I don't understand is the leak test (DICHTHEIT/dichtheitsprüfung) results. It says that both intake and exhaust both drifted prematurely (Einheit vorzeitig weggedriftet). Is this actually a problem or does it always say this? Looking at all the other post they all seem to say this.
  • BMWfanz
    Your exhaust camshaft does not reach the end stops (0 - 45). It also doesn't use the full range (+45 degrees). Doubt it would be a timing issue. More solenoids and or piston seals.
    Yeah, always different values in each test, already installed beisan kit on mechanical vanos part, didnt maintaned solenoids. Now i'm in doubts- buy new coil pack or whole vanos module, but ECU didnt show any error codes on vanos or camhaft position at all
  • Tomba
    JOB_STATUS = OKAY
    AVAN_ISTWERT = 36 00 24 .$
    AVAN_SOLLWERT = -10 FF FF FF F6 yyyo
    Nr 6( 1) : 16.09.2023 16:01:23,2
    JOB_STATUS = OKAY
    AVAN_ISTWERT = 39 00 27 .'
