  • Tomba
    I always use Tool32, Seems the ipo file for the M3 was not covered with these functions.
    - open (F3) [mss54ds0.prg]
    - select [STEUERN_EVANOS1_VERSTELLZEIT]
    - hit the [1=>] button on top. Idle speed will be increased and your engine may sound a bit wierd during the operation
    - If OK, you will see a time in miliseconds, for EVANOS (Einlas VANOS = intake) I would say reaction time needs to be below <300ms. For exhaust (AVANOS) times may be a bit less as it has a angle to cover <250ms
    with, [STEUERN_EVANOS1_FRUEHANSCHLAG] you can force the end points of the VANOS. It will demand for instance 70 degrees while it should do a maximum of 60 +/-2 degrees.
    Run [STEUERN_EVANOS1_SPAETANSCHLAG] and it will run the opposite direction. Target -10 while 0 +/-2 degrees should be reached.
    Intake 0-60
    Exhaust 0-45
    with [STEUERN_EVANOS1_DICHTHEIT] you can see if the current position is maintained (leak free).
    I can make a *.tst file for you if you prefer that. You just load in that file and run it (F8). It will do things more automatic and prints the results in the Results screen.
  • boadly
    I'm really confused about INPA. I see videos like the ones below where INPA provides many functions for non M E46's. The attached screenshot from one of these videos I guess is not an actual vanos test but does provide some vanos data for a non M E46. Other functions I've seen include bleeding the brakes. I reinstalled INPA one more time using the Bimmergeeks download but still can't do any of these things. Under chassis the only thing I can get to work is the steering angle sensor (second screenshot). No brake or ABS function. Like I said I've tried with two different DCAN cables with the same results. Can someone confirm if INPA will not provide these functions for an E46 M3 or if I may have some other problem? Don't know if it would matter but I do have a custom tune. Thanks for any help as I'm really getting tired of trying to figure this out.
  • boadly
    Originally posted by Dash1 View Post
    Yeah I'm not aware of VANOS test being available on inpa. I have ISTA+ and am having a hard time finding the VANOS test. Youtube videos don't have the same options I do
    Yeah, I wasted several days trying to get ISTA to work with a dcan cable before someone told me I needed an icom cable to make it fully functional. I could read codes and some other general functions but none of the testing I wanted to do. I did a little research on ICOM cables and it looks like there are several different kinds and are much more expensive than a DCAN cable. Not sure if I want to spend several hundred dollars on another cable. Does anyone have a recommendation for an ICOM cable?
  • Zekarus
    you will need an icom device for ista+. if you don't have one, stop trying, you won't be able to perform the test.
    k+dcan -> DIS
    icom -> ISTA+
  • Dash1
  • Martyn
    You can't do a vanos test with INPA, you need DIS or ISTA-D.
    From memory, Analog 3 will give you current vanos postions
  • boadly
    started a topic Need help doing vanos test with INPA
    I'm trying to do a vanos test using INPA but it seems like it's missing that and some other functions. I can connect to the car and get error codes and engine data like rpm, temperature, etc. but it doesn't appear to be fully functional. I've tried two different DCAN cables with the same results. I've reinstalled INPA several times from Mike's BMW Easy Tools but still can't seem to get it to work right. Attached are some screenshots. The YouTube videos I've watched have a vanos button in the status screen but mine doesn't. My car is a 2004 M3 and I'm using a Windows 10 64-bit computer. Any help would be greatly appreciated.
