Good afternoon,
I recently swapped the stock seats for a set of E85 sport seats. I disconnected the battery and swapped the E46 seat goodies onto the E85 seats and everything matched up fine and went together no issues. Once I connected the battery up and went for a test drive the airbag light came on in a mile or so. I tried to use INPA to check the airbag codes and see where the issue is, but I can't access anything under the Body in INPA. I have tried two versions of INPA with the same result. I can read and access the Engine and Chassis side though. I have this https://www.amazon.com/dp/B07L498NGZ...d_asin_title_1 K+DCAN dongle, and I verified the 7/8 switch functions with an omh meter. I also have a BlueBus, but disconnected that, because I read somewhere that could cause a faulty reading, but same result. I get the no control from response unit when I try to access the airbag, but I get command not accepted when I try to access the instrument cluster. Or vice versa. Am I missing something? My windows and all lights work fine, the only electrical issue I have is the keyless entry is intermittent, mostly not working. I would guess 10% of the time I try the remote unlock/lock it works.
Thanks
Jonathan
Thanks
Jonathan
