I have an s54 I converted to a MAP sensor with a CSL box. I had a tuner load a base tune on the car for the list of mods I provided and now the car is throwing codes:
107 Electronic Throttle Self Test
119 Electronic Throttle Potentiometer Bank 2
120 Electronic Throttle Potentiometer Comparison
To diagnose:
I believe everything as far as wiring is concerned is all ok and is not causing this issue (please let me know if I missed something)
The only other things I can think of is the pedal actuator is bad or the file the tuner loaded is not a CSL variant.
I don't have too much knowledge on CSL vs standard M3 tunes but I have read they are different and the CSL relies on the TPS and MAP sensors a differently.
Can anyone chime in if either of these could be the cause or give any advice on what I should do here?
Any way for me to verify a CSL tune on my own using tunerpro?
I've asked the tuner three times now to verify this is indeed a CSL tune with no response.
To diagnose:
- I checked to make sure there was nothing interfering with the throttle body linkage and it was moving freely
- I checked to make sure all my pins were in the correct locations going into the DME for TPS and MAP sensors
- I've ohmed out all wires for bank 1 / bank 2 TPS and MAP sensors, all checked out ok
- Checked all the grounds for the sensors, all ok
- Checked for any shorts in the wires, all ok
- I back probed and checked voltage going to the TPS's, during the back probe these were the results:
- Bank 1: 5v in .418v on the sensor 0v on ground
- Bank 2: 5v in 4.15v on the sensor 0v on ground
- I replaced both TPS's on bank 1 / bank 2 and the pedal is also brand new.
