Tips on cleaning back window in a car with a roll cage
    My back window needs cleaning on the inside...bad.
    Anyone have an easy way to do it? Right now it’s turn into a human contortionist and wiggle on back there.
    Find some neighborhood kid and give her $20 a spray bottle and lint free rag.
      Sounds like child abuse...lol
        If its hot in the car give them a soda. Problem solved!
          Slither in there and get 'er done. At least you'll know it will be done right and not be looking at white streaks.
          Bring a wire to pick out the dead insects at the base too.
            With the condition of my back I would need to take out a seat to do this as I have both passenger and drivers seat.
            My 6 year old does a decent job I must say!
              Hope you heal up soon. Don't forget to wear your HANS.
                PO installed tint on the back glass (long before I put a full cage in). I get one free cleaning when I tear it off. I will use it wisely.
                Can always use the squeegee on a stick method.
                '02 e46m3 - fully caged track car
                many others
                  That residue is going to be such a B. Which reminds me to take my tint off before the cage goes in this winter.
                  2003.5 Titanium Silver / Black 6M/T (Gone)
                    It peeled right off the back side windows. Hopefully it'll be the same for the rear glass whenever I do remove it.
                    many others
                      Nice! Hopefully mine is like that also. the last car I took it off left a bunch of goo
                        Microfiber on a swiffer, spray glass cleaner directly on the microfiber.
                          I’m probably going to just climb on back there.
                            The biggest issue will probably be dust, at least it is for me except for that one extended off track plowing experiment....I bought a giant duster to keep the back clean, and with extensions on a shop vac you can get where you need to be. IIRC Stoner (the maker of invisible glass) makes a triangle pointed wand you can attach a microfiber to (typically for windshields) to get in the hard to reach areas. I use it for the areas I don’t want to climb in and get to...
                            Wait a minute, are y’all saying your tint removed fairly easily? That is something on my list. I was planning on going at it with a steamer but peeling that off would be like heaven.
                              Here you go buddy:
                              Invisible Glass works better, removing fingerprints, smudges, and grime, leaving your glass clean and streak free. The best glass cleaner.
