Which lexan windows are you running?
    I'm at the point where it is time to select some windows for my track car project and I am curious to know what you all are running on your track cars?
    Looking like Five Star Racecar Bodies is the most popular:
    Proprietary optical grade polycarbonate window for the right rear quarter on E46 2-door coupe models.
    Proprietary optical grade polycarbonate window for the left rear quarter on E46 2-door coupe models.
    Thoughts? Any other options that I should be looking at?
    Thanks!
    Instagram: M3Journal
    I bought a windshield and back window from Five Star Bodies. I got a custom size that is 1/8 thinner than what they normally sell.
    Be prepared...you will likely need to brace the windshield and rear windows. Mine were flexing quite at speeds over 80mph. The passenger side still bows in and it scares most passengers...only if I cared more to put another brace on the windshield. My braces were an after thought. Could have made something better if I planned ahead.
    I had these installed by a normal auto glass guy like a normal window.
      Originally posted by M3logik
      Thanks for the input. I'll probably go with the standard thickness for the rear window. For the front, I'll probably go with a stock windshield.
      Do you have many scratches on the windows due to cleaning and rocks, etc?
      It’s been 4 years and it still looks good.
        I would not recommend the poly side rear quarter panels from Hard Motorsport. The attachment hardware is great but the fit is fair at best.
          Par for the course for anything Hard MoSpo. I avoid them at all costs.
            Right!? I feel like more people need to know about this. Perhaps they do. I bought their molded door panels knowing that they provided a caveat about "fitment issues." Hilarity ensued. I tried to install them and the fitment was a joke. Contrary to my best judgement I took the car to a body shop where they called me a couple days later and said it would take them a half a day to "look decent." I use them under my oil change pan now to catch any splashes or drips. They are doing very well in that role.
            The scariest part of the entire thing is they sell a carbon fiber version of the panels. I legitimately feel bad for someone who purchases the early run of those, as they are presumably based on the same cast as the others.
              I wrote Hard Motorsports off awhile ago
                If anything you’d want lexan on the windshield since it is shatterproof.
                  Hah I thought it was just me! I avoid them now as well. Everything I have from them is garbage, bar the HVAC panel, that fit well enough. I don't buy from them anymore though.
                  '02 e46m3 - fully caged track car
                  many others
                    Five Star Bodies.
                      Ended up going with the Five Star Racecar Bodies windows (rear + quarter).
                      What glue are you all using? Also, I'm seeing no rivets for the rear window. I suppose they are not required?
                      You can just install the back window like normal glass with an adhesive. You may want to brace it if it starts to flex too much at high speeds.
                        Hard Motorsport. Hate them. Clever attachment design. Hilarious fit. (Rear Quarters)
                          Dumb question inbound: but excluding the rear windshield, if you go Lexan on each of the sides, do you tradeoff power/functionality and do they all (likely) have to be braced? I guess my question, simplified, is are any Lexans for our car just remove-to-plug and play?
                            I've only seen lexan side windows screwed to the body so you'd lose the power window functionality.
                              And the front/rear - are they always riveted/braced?
