I’m pulling about 1.5-1.6 lateral G’s on fresh Toyo RR’s. I imagine it will be a little more if I throw on some Hoosiers.
I imagine as long as oil pressures are good then it’s a non issue. I don’t data log oil pressure. Maybe I should start but wanted to see if there is a known limit.
At what point does the OE oil pump need to be upgraded?
What are the upgrades? I know one is a dry sump. Not opposed to that, just looks complex. Besides all of the components, have to consider vacuum, gaskets, seals, and maybe other things I’m not aware of.
