Common wisdom - track wheels and tires
    Front or rear tire?
    Either way, that isn't abnormal.
    The tires wear that way in front and rear posiition.
    OK, maybe it's not abnormal. But I'm surprised by the odd wear pattern on the outer edge of the center tread. If I had to guess, that will be the first place on the tire that will be completely worn out.
    Maybe that tread block should be more rigid than it is for track use? If it is user error due to tire pressure or alignment, then I'm surprised (but willing to learn). I take careful psi measurements after every session and I have a reputable race-shop-performed alignment.
      Can't say that this is an alignment issue. My guess would be PSI, tread design or tire compound. Tires look like they are at the wear bars, so that center wear seems like it would be acceptable.
      This thread might help - https://www.m3post.com/forums/showthread.php?t=1607489
        What PSI are you running? And does the shop do a string alignment or a laser alignment. Laser alignments are much faster but not always as precise than a string alignment. There is an art to it and even then even the BMW specified Hunter alignment rack will not be 100% repeatable.
        Wear is an indication of excessive heat. That kind of looks like toe wear but also could be camber wear.
        I run -3.8 F and -3.0 camber front and rear and target hot PSI is 30 hot, I'm OK with as low as 28. Cold target is 6 psi lower in the morning which gets me to about 28psi hot for the first session. I get even wear across the face of the tire. My car is also 2825-2875 with fuel and driver. Sounds like your car is heavier, might need to add more negative camber front and rear, probably more than me because your car is heavier. Then toe settings become more critical for wear. Really need to be at zero on the front axle. I target half the toe as the stock spec on the rear.
        A starting point for most tires is psi every 100 lbs as driven. So a stock car with driver and fuel is around 36-38psi hot.
        Could also be a bushing issue. Rotating tires makes it more difficult to pinpoint the problem. A spherical RTAB significantly improved my tire wear over a relatively young OEM RTAB with limiters.
          There's a lot in there - thanks for the link!
            27 psi cold (or prior to a session start) with psi somewhere around 35 psi when coming off the track.
            I don't know. I have chosen a nearby race shop (RRT Racing) based on reputation and familiarity with the E46.
            That's interesting. I have relatively young OEM RTAB with limiters and OEM FCABs. Although I didn't think about this as a contributing factor to tire wear, it converges with the only recommendation I got on car setup from a very experienced driver that drove mine for a session. His thought was "setup is awesome, maybe a bit more front camber and delrin bushings".
            Also from last weekend: Estoril let me borrow his contact pyrometer to take temps and the inside-center-outside temperature range was fairly tight. < 10 degrees variance from 12 different measurements when I drove and <5 degrees variance and 5 degrees lower when the more experienced instructor was in my car.
            My conclusion from looking at other RE71RS users is that this wear pattern is common, even on instructor's cars. I'm not the only one that hasn't figured out a way to prevent it.
              Question for the folks running 275 width NT01's on a 9.5" rim. According to Nitto, the tread width of the 275 in both 17 and 18 inch is 10.6". Are you guys having any issues with this rolling under? 10.6" seems too wide for a 9.5" rim.
              Old, not obsolete.
                You'll be fine. I've done it before with 17" wheels
                  Thanks.
                  Is this more an issue of chasing absolute grip, rather than optimizing tire size for the rim? Does the increased heat tolerance of a physically larger tire figure in?
                  Trying to learn as much as possible before dropping a bunch of money on track wheels and tires.
                  Old, not obsolete.
                    Thanks.
                    It is about maximizing the contact patch so yet...grip. A wider tire on a wider rim should result in a larger contact patch, not sure it would affect heat tolerance.
                    If you are talking about the outer diameter, that affects tire temps. A smaller diameter tire sees more revolution at a given speed which generates more heat. Also changes the final gearing.
                      Anyone try 18x10 ET25 square? I am told it will work with -3.5 front.
                      Old, not obsolete.
                        No rubbing with 265/35R18. Ride heights 13.75 front 13.25 rear.
                        Old, not obsolete.
                          I run 275/40R17s and need about -3 camber to clear. Might be able to squeeze a 285. I think you could squeeze a 295 on a wider wheel with a lot of neg camber.
                            Thank you sir. Good to know. 10" width? Offset?
                            Old, not obsolete.
                              17x10 et25. I run this purely for cost savings. Tires are typically $50-$70 less per tire in a 17 vs a 275/35R18. Only downer is selection is more limited.
