Delete A/C compressor - what serpentine belt?
    What belt, and what routing are you using after you delete the a/c compressor? ChatGPT says:
    The 6PK1165 belt length is commonly used in A/C delete setups for the E46 M3 and has been verified by multiple track car builds and forum discussions. It follows the standard accessory belt routing but bypasses the A/C compressor, which allows the existing tensioner to take up the slack. Belt Routing Without A/C Compressor:
    1. Crank Pulley
    2. Power Steering Pump Pulley →​​
    3. Alternator Pulley
    4. Tensioner Pulley
    5. Back to Crank Pulley
    The key difference in routing is that without the A/C compressor, the belt forms a direct loop from the crank pulley to the power steering pump instead of detouring down to the A/C compressor.
    Why 6PK1165?
    The OEM belt (6PK1195) is 1195mm long, and removing the A/C compressor shortens the required length.
    • The 6PK1165 is the closest available size that maintains proper tension without overloading the tensioner.
    • This size has been tested and confirmed by various E46 M3 owners performing an A/C delete.
    The A/C runs off its own belt. Remove the belt and compressor to delete A/C. Could probably save some more weight by removing the A/C belt tensioner as well.
    A quick visual observation of the engine bay goes a long way
      Yep. Multi-tasking. How embarrasing.
        What does this say about chatgpt?
          Not sure...I think my prompt included "M3"...
          It's one of my sillier questions to ask. I was thinking..."I know I bought an A/C belt before..." . I'm fairly sure I wasn't drinking at the time.
            Are you deleting everything related to AC?
              Good question. It's part of a larger project for 2025 - now that I'm using a trailer. So, I'm open to advice.
              My plan is to reduce unnecessary weight on a car, since we don't drive to the track anymore and we have a FAST cooling system. I plan to remove the condenser, the auxiliary fan, the dryer, the lines/hoses, and in the process the refrigerant . At the same time, I'm also going to pull the front carpet, the passenger airbag, side curtain airbags, and airbag module.
              I don't plan to remove the heater, and I haven't figured out how to dehumidify the car for early morning sessions in high-humidity without it.
              (I've already removed the door cards and replaced with turtle labs aluminum option because I didn't like how the OE armrest got in the way of my elbow.
                Just curious, no advice.
                  Pulled these parts of the AC out today. 41.5 pounds in all.
                    I live in Houston. I have no heat, AC, or wipers. I never have an issue so long as I cover the car or store it inside a garage.
