Originally posted by S14
View Post
Front end sway bar links?
Originally posted by S14 View Post
I didn't listen to your advice and went with the bimmerworld street/track links and they are already clunking/popping 2 weeks after install...
That's weird. Did you dial out the preload? You might want to add *slight* preload to see if the clunking stops.
Yes, I took the slack out when the car was on the ground. Good idea though, I'll mess with them a little bit before returning them.
Originally posted by ZHPizza View PostI've seen it done with a set of Meyle HD links, which are a little larger shaft diameter than OE. I don't see a drawback as long as you get the alignment right to avoid binding. Maybe draw some alignment lines on each end to keep track while tightening.
