Originally posted by S14
Front end sway bar links?
That's weird. Did you dial out the preload? You might want to add *slight* preload to see if the clunking stops.Originally posted by S14 View Post
I didn't listen to your advice and went with the bimmerworld street/track links and they are already clunking/popping 2 weeks after install...
Yes, I took the slack out when the car was on the ground. Good idea though, I'll mess with them a little bit before returning them.Originally posted by eacmen View Post
Only thing I can think of is that the stud on the end link isn't sized right for your strut/sway. Might want to call up BW and ask. I've found them very helpful. I use them for most of the parts on our track car.Originally posted by S14 View Post
I have Lemforder links, I should really take a caliper and measure the diameter to see if it's close enough to a standard thread size. At least if it's around 8 or 10 mm I could either do M8 or M10, if slightly smaller there is correspondingly 5/16 or 3/8. Might just be hard to find a LH thread M8 or M10 tap and dieOriginally posted by ZHPizza View PostI've seen it done with a set of Meyle HD links, which are a little larger shaft diameter than OE. I don't see a drawback as long as you get the alignment right to avoid binding. Maybe draw some alignment lines on each end to keep track while tightening.
Reviving this after installing Whiteline adjustable front sway bar end links I got from Vorshlag. I have MCS 2WNRs and have run OE end links and briefly tried Bimmerworld adjustable which were immediately noisy. The OEs worked ok but can't adjust out preload and were very close to the front control arms. Really happy with the Whiteline end links, very easy to adjust, have sealed joints and are dead quiet. Recommend.
