As far as I know Only certain mk60 models can be flashed with the motorsport file. Not aware of any file you can just flash, but certain companies will take your module and flash it.
Thanks. Can you disclose the companies? If not please send DM. Thx
In regards to ICE mode, I would check the yaw sensor is not faulty or moving around. After that, you could just flash the MK60 to the motorsport file and get rid of ICE mode completely. I had the same issue as you. I would press the brake pedal sometimes and at some point it would go hard and the car would not stop anymore. It was not brake fade as I had brake pressure and feeling for every corner of the track except for that one corner, periodically.
I thought you can just use the AnalogX and tap the CANBUS into the car's CANBUS. Just make sure the AnalogX has an address that the car does not currently use. Am I missing something?
I just have the MSW brake pressure sensor go to my MXP. The kit uses the rear brake pressure and not the front brake pressure.
You might want to double check with Morehead Speedworks, but I don't think you can add any channels to the Aim Solo.
AFAIK you will need to upgrade to an MXM (but I'm not sure if it can do canbus) or switch to Racecapture.
If you’re able to add CAN PIDs this is a viable option as well:
I want to pull data from my AiM Solo DL for brake pedal pressure. I've gotten to a point where my time improvements are in braking and corner entry. Improvement is much more difficult and slower without data. I've thought about just unplugging the pressure sensors and installing an AiM sensor. Just looking for some input before I start experimenting.
I've deleted the DSC sensor since I don't need stability control...my right foot is my DSC. I've driven without the DSC sensor for the last 3 years. The only thing I've noticed is that the brakes will cause the car to not slow down as quickly if I overcook a braking zone. I don't get the sensation of the brake pedal pulsing. Is that ice mode? I can still steer the car which tells me that the ABS is functioning. I've never gone straight off with the wheel turned...which is what I would imagine is the result of ice mode. No tire smoke unless I'm 90 degrees to the intended path of travel and I go 2 feet in. Although the website says that deleting the DSC sensor degrades ABS performance...I'm not sure that it really does.
Here are the options:
1. One solution is Morehead Speedworks makes a latch line... MSW AiM E46 Brake Pressure Sensor Kit (Mk60) - Morehead Speed Works. I know him (I was his instructor when he drove a Z3M). I like the product but I also prefer to keep things as close to stock as possible which makes troubleshooting and repairs much easier and OE is generally more reliable.
2. Remove the OE pressure sensor and install the AiM sensor. I could find or fab an adaptor to fit an AiM sensor into the front line and then just unplug the rear OE sensor.
3. (Most ideal) Or is there someway to pull data from the MK60? There is a lead for MIL status...does that also provide data?
