*** The datacenter where this server is so graciously hosted is going to be doing power maintenance. During this maintenance, I will be shutting down this server and nam3forum will be completely offline.
Start: 5/22/2024 4:00pm PST
End: 5/23/2024 6:00am PST
New 2.5" GC rear adjusters/perches with Eibach extra travel 6" 600lb springs
The red cylinder and gold perch sit over the red reinforcement plate which all sit on top/around the "nipple" of the lower control arm. Then the cad plated bolt and big washer go from the underside of the control arm up into the red cylinder to tighten it down. Then the spring sits on top of the gold perch, obviously. Up top, you can use a locating cone like GC sells or RE ($60 iirc) or even just use the stock rubber upper pad.
Also, these springs are a little special and are actually $105 each! They provide for a little more travel before blocking than a typical standard 6" linear spring.
