Just wanted to check here before buying from the site.  Anybody have a set for sale? Let me know!
WTB - Dinan TBs
 WTB - Dinan TBs2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod BearingsTags: None
 Thanks!Originally posted by c watson View PostYou can get them through autotalent and get 5% off, no tax, and free shipping. After the core you’re looking at around $1200.2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
 MpartsWW has a set for $1200 and Recyclebmwparts (IG) had/has a set for $800, but that was some time ago now.2004 Silbergrau Metallic 6MT
 Ended up buying direct from Dinan. It’s worth getting them there because the kit includes replacement o-rings, hardware and clamps, which are valued at least $350 if you chose to buy them separately. The TB synchronization TIS states the nuts and bolts are one time use!2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
 What’d it run you after the core ?Originally posted by duracellttu View PostEnded up buying direct from Dinan. It’s worth getting them there because the kit includes replacement o-rings, hardware and clamps, which are valued at least $350 if you chose to buy them separately. The TB synchronization TIS states the nuts and bolts are one time use!
 Still need to return the core to see how it settles out. The only reason I hesitate to answer is because I got a military discount from Dinan. My total with core charge was $3170. I’m not sure if they discounted my core charge or not. Core charge is typically $1950. Either way it was worth the slightly extra money to go new for this IMO.Originally posted by c watson View Post
 What’d it run you after the core ?2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
 Dinan essentially performs this service in-house. When you buy their product they bore out core TBs that have in stock and replace the butterflies. You aren’t necessarily getting a “new” part. VAC does the exact same thing.Originally posted by Feffman View PostDoesn't somebody machine out the throttle body if you send your set in? I saw that somewhere.
 Feff2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
 Factor in a CSL intake that feeds more air, cams that use more of the air, 2.5in exhaust that exhaust more of the air. I'm sure those numbers would look different then.Originally posted by Mayan-Viking View PostI don't understand how these TBs can be perceived as a great ROI for these cars. $3,200 (on sale) for a product that produces 6 hp and 4 LB-FT (only when paired with Dinan with software) seems like a crazy value prop to me. Or maybe I'm missing something?2006 Silber Grau Metalizat ZCP 6 MT
 That's where I saw it ($1,400). https://store.vacmotorsports.com/vac...s54-p2430.aspxOriginally posted by duracellttu View PostDinan essentially performs this service in-house. When you buy their product they bore out core TBs that have in stock and replace the butterflies. You aren’t necessarily getting a “new” part. VAC does the exact same thing.
 Wonder if these are good for 15+ whp with all of that. Might be worth it for $1200. I could get some and dyno before/after.Originally posted by CrisSilberGrau View Post
 Factor in a CSL intake that feeds more air, cams that use more of the air, 2.5in exhaust that exhaust more of the air. I'm sure those numbers would look different then.Last edited by EthanolTurbo; 02-06-2023, 04:03 PM.Instagram: @logicalconclusion
 They aren’t $3200. That price includes a core charge of $1950. After you get that back it comes out to around $1300. Are there better mods for the money? Sure, but I’ve done pretty much everything else with my build. Choose your own adventure.Originally posted by Mayan-Viking View PostI don't understand how these TBs can be perceived as a great ROI for these cars. $3,200 (on sale) for a product that produces 6 hp and 4 LB-FT (only when paired with Dinan with software) seems like a crazy value prop to me. Or maybe I'm missing something?2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
