Diffsonline 4.10 differential
    Like the title says, diffs line 4.10 diff with about 5k miles of use. Works flawlessly absolutely 0 noise. located in Atlanta GA will ship at buyers expense
    price drop 2500$
    solddddd
    Is it the whole unit?
      Yes Straight drop out from my car.
        Is this stock m variable? Or different limited slip? If so what kind, possibly interested if not stock M variable
          I was told by the PO that this was a 4.10 from diffsonline. But is there a way to tell? I can pops the cover off to see if it shows anything .
            Abduman, Im pretty sure you can count the splines on the ring and pinion to tell, Sid can probably give you a more clear explanation.
              i think the question is what kind of 4.10 diff is inside. There’s many variations diffsonline sells.
                I think fullyflarredd means is what's the actual differential. The 4.10 is the ring and pinion, the differential unit is either stock m-variable or aftermarket like os-giken or custom by diffsonline possibly
                  He is asking what type of lsd/center section it is.
                  4.10 is just the ratio of the ring and pinion gears
                    I wouldn't just assume anything, you can easily verify its a 4.1 just counting rotation
                    Sent from my iPad using Tapatalk Pro
                      I’ve taken some pictures with the diff cover removed. Some numbers I saw I took pics of. Hopefully someone can help me figure out exactly what this one is. I’m leaning towards m variable .
                        I really appreciate the pics with the cover removed. Unfortunately I genuinely have no idea how to identify it lol.
                          Yep this!
                            Looks like a V1 M variable differential
                              thank you!!
