FS: Rebuild SMG Pump w/MLR seals and new MLR accumulator
    As some of you followed in my other thread, I rebuilt two SMG pumps with new seals, pumps and accumulators. Here is my second pump for sale which I tested over the weekend to ensure functionality and proper pressure buildup. I did not install the new motor (I used an older motor to test), but the new OEM motor will be included.
    1. MLR full SMG pump seal kit ($200)
    2. New SMG pump thermostat ($25)
    3. New SMG pressure sensor ($90)
    4. New MLR upgraded capacity accumulator ($600)
    5. New OEM pump (unsoldered, unpinned) ($300)
    You’ll need to either (1) solder the new pump to the harness (pretty easy, I just didn’t do that on this pump) or (2) get new pin connectors to use on the new pump. Option one is the fastest and easiest and is what I did with the other pump.
    The pump itself was from my 52K mile M3 SMG convertible (since sold, had done a pump relocation with another low-mileage pump). Nothing was wrong with the pump, I just did it out of boredom.
    I’ll bolt the motor down and apply the appropriate grease in the pump/motor connection, and I’ll also install the factory brackets in the event you’re installing in the factory location.
    $1,500 shipped and insured!
    Bump - unless otherwise requested, I’m going to solder the new motor to the harness so that it will be plug and play.
      Do you still have this for sale?
        Yes, sent you a DM.
          Bump.
