what are the best brakes to upgrade to?
    Drive like Miss Daisy and they squeal.
    Drive like you should and they don't.
      The AP vs Alcon threads are legendary on almost every car forum. The same old stuff gets repeated.
      If we pop on down to planet reality, I suspect that average Jo would never notice the difference. There are other factors that typically influence the decision.
      I went with alcon because its what I had on the evo (so a known quantity), what my friend Jim has on his M3 (which brakes just fine) and the front discs/pads are the same as my evo, so I can keep one set of spares.
      Common sense tells me that a larger disc will dissipate heat better and allow for a bigger pad surface therefore a bigger braking force. But common sense can't always be relied on.
      I've spoken to a number of people about the front rear bias problem that has been discussed and not found anyone just yet who agrees or thinks that if the setup felt wrong, it could not be cured by different pad choices. I don't wish to argue this point lawsy, I accept that car characteristics are a personal opinion and you believe the AP setup to favour your driving; fair enough but in the interests of balance its worth pointing out that this isn't a universal view.
      Either will be awesome compared to stock :-)
        Wheres the best (cheapest ) place to get a set of these Alcons? is there anywhere that supplies them for the same sort of money as Lawsy's Evo contact?
        They shouldn't be any more as it's the same kit just with a different alloy bell and mounting bracket :thumbs:
          Mine came from thorny, £3.3k if I recall.
          Its difficult to get "a cheap price" on alcons. Unlike AP they are only sold few a through channels in order to protect the brand. Reassuringly expensive ;-)
          Ears couldn't match my thorny price for the unbranded alcon kit. So I went with the csl cup kit. As to whether you prefer the colours, thats personal.
          One of the guys at alcon pulled the spec sheets and confirmed there was no difference between the csl cup kit and the alcon-stamped kit.
          FWIW, I would recommend the carbotech pads. Lesser known as a brand, but I've been using them on other cars for ages and they seem more friendly than pagids. Available in a whole host of compounds, XP10 front and XP8 rear is a good combo, ace on trackdays, works fine on the road. Wheel friendly.
            Yes, agree with Titan.
            Alcon are VERY protective over their few distributors. I actually know someone at the factory and there was absolutely no chance of a mates rates set!
            Titan, how much do the carbotech pads work out for £££? for a set.
            Jonathan
              Jonathan
              Approximate £200 notes maybe £230 +vat
              I run them and I find them personally better than the pagid rs
              Just my view
                This is incorrect if you do the math.
                The Alcon is the only aftermarket brake kit out there that I know of that more or less retains the CSL brake bias out of the box. I did the math and it adds up.
                See below.
                Standard setup with an equivalent brake pad compound as the front Alcons. I am running pagid rs29 on the front alcons and performance friction pfc01 and the brake balance is "perfect" (quote from a veteran champion professional racing driver and acredited bmw driver training instructor who took my car for a test run around a new track yesterday and provided me with some setup feedback)
                If you want me to get really technical I can ... but as a reference.
                The stock E46 M3 has a front to rear brake bias ratio of 1.98 (i.e. front heavy)
                The standard CSL has a front to rear brake bias ratio of 1.73 (i.e. shifted slightly to the rear compared to the stock M3)
                The standard Alcon kit in both front and rear configuration has a front to rear brake bias ratio of 1.78 (i.e very close to the stock CSL setup)
                Running just the front Alcon kit and retaining the stock CSL rear setup gives a front to rear brake bias ratio of 1.82 (so in between the stock M3 and CSL setup - which I've found to be much much better).
                As for those going with the AP racing kit - those kit are actually WAY MORE rear biased compared to all the other kits out there. For e.g. the 5570 kit has a front to rear brake bias ratio of 1.61 (very rearward biased).
                Correct me if I'm wrong but isn't the CSL bias 2.17 ie more front biased than the regular M3?
                  Oh no - now you've done it! :banghead:
                    Get AP racing! They are bullet proof!
                    Mine's had 2 heavy-on-brakes trackdays, and 2 trips to the Alps and they're still happy bunnies. I've only had them for 6 months, and bought them second hand from a CSL owner that only tracked them.
                      Given the choice I will be going for the Brembo Gran Turismo kit which has fully floating discs and alloy bells all round.
                      I don't like the bolted front discs and standard rear discs on the AP kit which makes them seem the low budget option, and I don't fancy having the heavy Alcon hats on the rear.
                      Brembo's tick all the boxes for me:supz:
                        Good shout, you need fully floating disks and alloy bells for the odd track day, pretty sure the AP kit wouldn't cope.
                          I have the same experience Nathan
                          APs are good only for supermarket use :whistle:
                            Sorry, I thought the question referred to what are the best brakes, not what's the best value.
                            I agree that Brembo are a very expensive option, but it was just an opinion on what I consider to be the best in all area's
                              If price has nothing to do with it then you could do much better, carbon ceramic are miles lighter.
                              Truth is that any AP, Alcon, Brembo etc etc kit will be fine for track days and road use so why spend more than you need to unless you just want the bling. Personally I don't like the amount of holes Brembo seem to stick all over their disks, great way to reduce the friction surface area.
                                You have the choice of drilled or slotted with Brembo.
                                Granted, the AP and Alcon kits are excellent brakes. I was simply pointing out their weaknesses. Just being honest.:beer:
