what are the best brakes to upgrade to?
    Well I saw M5 Powered Alcons on Saturday and the colour of the calipers matches the SG exterior brilliantly, so that gets my vote :hahaha::hahaha:
    (Thats my contribution to the tech section, I'm off)
      Rob, all I was saying is they are not bullet proof
      I know mate, i know... :goodman:
        :hahaha:
          :smt069
            Originally posted by Foamy View Post
            Yes, that's a budget option, but no one can claim it's going to be as good as a properly designed big brake kit from one of the big manufacturers.
            Originally posted by M5 Powered View Post
            +1
            I wouldn't put a Big Brake kit on a car that it hadn't been designed for. Too many variables - the master cylinder for starters.:banghead:
            As already stated on this thread though - are the Alcon calipers not exactly the same as used on loads of different car's - evo's, jag's etc?
            So how are they 'a properly designed BBK' designed specificly for the M3?
            Or are the master cylinders, weights and brake bias' of all the car's the Alcon calipers are found on exactly the same? :hahaha:
            For this reason alone, how are they any better than using the Brembo's from a Porsche with mounting brackets and disc's to match?
            Fair enough if someone can give a proper technical explanation as to how they are 'designed' specifically for the M3 or CSL, but so far these 'proper BBK's' are just another big calliper and a means of bolting it to the M3 hub?
            James
              :smokin:
              James
              Tuning is like a penis, the bigger the better, well thats what a tuner once told me:smokin:
                James
                The pretty Brembo, Alcon, AP calipers might all look the same but there are many variations of each caliper.
                People seem to think a bbk is just any old caliper mounted to a bracket which aligns with the disc and Bobs your Uncle. I'm afraid it's definitely not the case.
                A proper bbk is designed using a caliper with the correct radius for the disc used.
                The disc should have the correct sized face to match the caliper and pad as well as the disc thickness.
                The piston area should be roughly the same as the oem caliper to keep bias correct.
                Alloy brackets on the fronts should ideally have steel threaded inserts and be hard anodized. Studs etc must be high tensile.
                If you think you can go on ebay and make up a bbk that's as well thought out as a pukka jobbie, then go ahead. I just wouldn't do it myself and I wouldn't buy a car that had one.
                Glwtbbk
                  Glwtbbk
                  What a load of bollocks
                  AP calipers are the same size, same disc size, same pad shape on many different style cars, many different weight cars.
                  The kits are identical, bar mounting brackets and hoses- car specific.
                  How much would it cost to test every different car/model and then slightly change design for each model? mega bucks.
                  Do you really think they will produce 1000's of different sized pistons or a few?
                  Just my view.
                    Just my view.
                    Yes, not 1000's but a few:supz:
                      Brackets CNCed out of one solid piece of high tensile steel are the only way to make decent & reliable BBK conversion brackets :thumbs:
                      Anything else and you might as well be making them out of cheese :hahaha: I hear Edam is quite good :whistle:
                        Poor old Colin Chapman would turn in his grave if he read this.
                          I like to think he'd thought ahead and would be spinning in his grave using lightweight bearings installed in his fibreglass coffin.
                            Lol :thumbs:
                              Who's Colin Chapman?
                                Charlie's brother
