What did you buy for your E36 this week?
    Finally got my Turnermotorsport Under panel, huge improvement over the MotionMotorsports panel
    motions panel is 2mm, Turners measures 3.25mm, brackets are 3mm and much better designed, the use of rivnuts is a better idea too
      I readjusted my parking brake. I previously only had one side of the brake engaging, and realized I had been adjusting the gear the wrong way for the other side. I also installed new brake sensors, as I was getting very tired of the lights coming up on the dash.
        New driveshaft, euro trans crossmember + CSL intake
          S54?
            About $2500 in S54 swap bits, despite still not having an engine in hand yet! 😂
            Once I find that engine though at least I'll be prepared.
              Precision composites wang fitted to the daily shitbox while my trunk lid is off at sodablast then both off to paint, even with OE riser PN stamp - fits just like OE (if you've ever fitted them before you'll know the deal 😂)
              Sent from my SM-G930F using Tapatalk
                Took the gamble on a set of AU$500 wheels, terrible ad with terrible pics of disgustingly dirty wheels (one pic i could see embossed letters so looked genuine). Few hours of degreasing, plastic scraper usage and cleaner and all 4 came up great with minimal curb damage, definite score!
                2 had old 215s stretched on so banged them on the daily to check fit and they are bmw hubcentric sized. Will end up with 245 ps4s all round for wets/dyno/motorkhana/club show days as they weigh in at 10.2kgs vs the ACS3s at 8kgs
                  The 328 coupe gets new window slider clips and door card pins.
                  It also gets new tie rods on wed.
                  The M3 gets a door striker/switch.
                    Got myself an original coupe GT spoiler.
                      Today I went into the garage and looked at it lol
                        New brake light switch this am.(over ten years of procastination)
                        That should inspire some other dash advisory to light up.
                        oh, btw, will the diff tolerate 75/140 castrol?
                          “Tested” my stock differential before swapping in a 3.64
                            You'll love the 3.64.
                            I used one with aggressive ramps in my e30 s52/320z swap.
                            New cowl trim for mine on the 'morrow.
                              Damn...bought a new 3/8" drill bit.
                              Key barrel spinning in the bracket and then the steering(with lock tension) lock pin was jammed.
                              Not good.
                              luckily it was the 328, and not the M3.
                                Picked up a new FSU and center vent lol
