[DIY] Selector Shaft Seal and Gearshift Rod Joint
    Originally posted by Brandon318
    I tapped the selector shaft seal in about 1/8" too far, think it's a big deal? Doesn't look like it matters much based on the pic of the selector shaft with the seal removed. Thoughts?
    Originally posted by OahuMPower
    you should be fine, as long as it made a good seal....
    I agree, it'll be fine - however the next poor SOB who has to remove it will be in for a treat!
      Nice DIY!
      UUC Double Shear FTW
        Hopefully me in another decade or so
          one of the couple UUC items I have....
            I truly miss my dssr....made for the smoothest and sturdiest shifts.
              exactly what i was looking for, thanks!
                no prob... .glad it was of help to you... I enjoy making up good DIY's when I can
                  Bumping.
                  Trying to remove my shaft seal since last night. My seal is not flush with the bore. It's deeper and I'm having such a pain trying to pry it out with no success. I'm able to grab little pieces of the rubber and try to pry them forward.
                  Now it seems that I can insert a pick between the shaft and the seal and I'm trying to pry it out from there and it's still not budging.
                  Trying again tonight hopefully I haven't scored the bore since I've been working at it.
                    Thanks Cal....big
                      Thank you so much Cal! Your guides are always so helpful. I recently installed the Rogue Octane SSK and love the results thus far, and this is a perfect compliment piece of work!
                        Just what I need, Thanks Cal. Mine is leaking very badly.
                        also do you know if the seal below the output shaft is known to leak too. I can't tell if it is just leakage coming down from the selector shaft or separate.
                          thats not a seal that i know of.... its just the selector seal leaking ALL over everything like usual
                            gotcha....it is a mess! going to go friday to see if the dealer has it in stock.
                            Thanks
                              be sure to wipe t down thoroughly with brakleen
                                nahhhh i was just gonna let it sit. You know how I like to do things Rich...
