As title suggests, would this work on an E36 M3...?
If this has been discussed already please just provide a link and read no further.
After 153,000 miles my T/O bearing is on its way out... Too bad as I feel the clutch has some life left. I think flywheel is okay but can't be certain till its out.
So...
I'm going to be replacing my flywheel, clutch disk, pressure plate (& obviously T/O bearing, seals, and the plethora of other maintenance items "while its out"). I haven't come across this yet in any of the forums but does anyone know if the new JBR "midweight" steel flywheel (p/n 520-010-240S) would bolt up to the e34 m5 sprung-hub clutch disk, factory M3 pressure plate, and T/O bearing package?
This to me would be an ideal package as you get a lighter flywheel, upgraded e34 m5 clutch disk, and "hopefully" no rattle or vibration issues. Seems like a decent upgrade that wouldn't add much cost over the stock package. I assume the combined weight of this kit would be similar to that of the stock e36 m3 as it is my understanding the e34 m5 clutch disk and pressure plate are slightly heavier than the m3's factory unit. Is there any reason why this may not work or wouldn't be recommended? What am I missing? My car is stock with the exception of a catback exhaust. It is my daily driver, but I do intend to do a few trackday/autox events here and there.
Thanks for any input.
So...
