What to Select (INPA) for the U.S. M3?
Actually, I thought I had to upgrade drivers (FTDI) then trying to understand why the BMW driver wasn't showing up under the COM ports in Windows 7. So, I would get headache dealing with Windows platform (Mac person) and give up. Then, I read INPA requires COM1...and to get older cars is shift F9.Originally posted by M_ParallelAll this time? You must have found out quickly that doesn't do anything. Like after the first try.
When in doubt, just try all untill it connects to the module/engine you're trying to communicate with.
So, I selected MS S50 for S50 M3 and got failure to connect...until I realize I was trying to pull up the Euro M3...looking back now I had to laugh.
On a 95 he shouldn't have any other port to go through, no?Originally posted by vmbrayAre you sure you have a good cable? There are a lot of poor ones that don't have all the connections you need. You're going through the 20 pin under the hood right?
Sent from my SM-N910V using Tapatalk
Agreed on the cable though. The quality doesn't matter in most cases. Sometimes you have to get in there and modify the connected pins. I use a USB to OBD2 "INPA" cable and then I split the case open to solder in a 20-pin connector lead that hangs off the side. They make OBD2 to 20-pin adapters too, but I didn't have one at the time.
Post a pic of you cable Nolli.
Well good point about no obd2 port. I bought a cable that works but I had to look around. It's a pain to solder and add pins but of course can be done. I've got one of those frankencables tooOriginally posted by Braymond141On a 95 he shouldn't have any other port to go through, no?
