Originally posted by Obioban
The evolve dyno obviously had a suspect strapdown as that behavior at the start happens when the car moves around on the rollers or transfers from rear roller to front roller. Ignoring that, the underlying trend is there.
The graphs below look more normal. I'm only using the evolve dyno as there is a lot of graphs around for both the E36 and E46.
the euro s54 is 365Nm peak heres a stock one, noting that the US spec one is 355Nm peak
S54B32
S50B32
At low rpm 2500-3500 the S50 has about 10-20Nm more than the S54 .
Your graph supports this and if you had of done the calculation correctly in post 156 you would have concluded the same.
