Well, of course he was, but if you change out the Euro invisa-cooler for a super-carbon rotometric cooling shield, you can squeeze into a 16" no problem.
So what are the advantages of the Euro floating rotors over a set of OEM US spec rotors or a set of good aftermarket slotted/cross drilled US spec rotors? Is it just looks? Or are there actual performance benefits?
Do you want to think about that question and ask again?
The mounting point is the same... you're using your same calipers... what part of the rotor do you think could possibly interfere with a wheel where the caliper wouldn't???
:smash:
Not all of us are experts in all areas of our cars. I thought that was a legitimate question. I have not yet begun to research brake components and therefore I still know very little about them. I thought the euro "disc?" might have a larger diameter and therefore our 16" winter wheels wouldn't fit. Once I get into brakes and do some serious research I'll probably see that this is a silly question, but until then I'll be the first to admit that I don't know EVERYTHING about my car (I'm sure there are others here who are the same way).
