" In addition, ASC+T will also activate the brakes in the rear wheels if necessary, and to varying degrees if frictional coefficients on the road differ...The ASC+T system knows when stability and traction have to be increased thanks to the ABS sensors, which provide the computer with a steady stream of data on wheel slip for each side of the car, as well as on changing speeds in the drive wheels. If the predetermined limits are exceeded, the control unit will instantly activate the traction system."
