School me on BMW/Porsche brake upgrade options.
    IT would be REALLY nice to find a caliper that would sweep the full 100% of the rotor surface......
    good luck with that...
      Yeah......once i figure out the dimension on the e36 mounting centers, I'm going to see what it takes to get the e46 ZCP calipers on our spindles.
      Essentially CSL brakes on an e36.
        Why??
        They're still single piston calipers. All you're doing is adding weight. Better to go with the Wilwood kit imho.
          Good morning everyone!
          Calvin hit the nail on the head in regards to the explination of the contact patch on the rotor. I was a little worried at first too, but TRUST me when I tell you this the braking power is WAAAY better than stock. (which is good)
          It appears that the mounting holes for our factory calipers is 2.75" from center to center. Here are a couple of quick pics.
          Good Luck!
            thanks Pete... now I dont have to get cold in the garage :woohoo:
              Good Luck!
              :shifty:
              Those are are the wrong holes! :chair:
              Those are the two holes that hold the anti rattle spring!
              On the caliper mounting bracket, there are 2 holes which the bolts go through to mount the caliper bracket to the spindle. THIS is the mounting center. What is the distance between these two holes?
              http://i77.photobucket.com/albums/j43/nees_01/img0050jgr.jpg
                Crap, My bad! Here is the correct shot.... It's been a while since I have looked at these parts.
                The holes are 4.75 on center. Sorry about that!:lolhit:
                  From mounting hole to mounting hole? Holy crap....
                    My god, am I having a rough one, let me try the pic again...
                      wow.. :facepalm:
                      self wned:
                        How in the world do you guys run wilwood calipers? They only have 3" mounting centers.....
                          with the adapter plate that we have been talking about that is required
                            hmm....thats quite an "adaption"
                              not really :clueless:
                              have you ever installed or done a BBK install?
                                Not really the mounting holes don't matter, that's why there is a bracket that come with all BBK's, at least the "super" BBK's.
