School me on BMW/Porsche brake upgrade options.
    Like Calvin said,
    The size of the piston bore can dramatically affect the brake bias (balance) the part #'s that I gave you are known to work well with our master cyl. set up. If you go to a piston that is too large, you can have too much front brake bias and also risk maxing out your MC.
    The bracket mounts to the stock cali mounting tabs, but rotates the caliper to a different position. No, you can not bolt on Wilwoods with out an adapter bracket. The measurement from the center of each hole does not match the factory measurement. The kit from UUC also came with shims, (Thin washers) to make sure that the caliper is centered (in & out) over the rotor.
    The set up will look like this installed>
    I hope that the pic worked, sorry if it didn't.:chair:
      If you want, I can take some add'l pics or a video without a wheel mounted tomorrow too! If you run stock 17" wheels (which I doubt) you will need to use spacers to get the wheel to clear the calipers. I don't need them with my E46 18's, but my 17" ltw's need a spacer when I go to the track. Let me know if you want a vid or more pics.
      Pete
        Like Calvin said,
        How come your pads aren't touching the inside ~30% of the rotor surface?
          just the way the caliper mounts to the large rotor... "way it was designed" :clueless:
          mine are the same way, and a reason why this kit only costs $1100 brand new
            Poor design. Which is why I will be going with a kit that is engineered to use the entire rotor and doesn't add unnecessary unsprung mass.
              Wow....I'm not sure how I fell about this anymore. This is "Normal" for this rotor/caliper package?
              Can anyone clarify the stock caliper mounting center on our stock spindles?
                wilwood kit is still > OEM
                wilwood kit is 50% the cost of any other major BBK
                wilwood pads are cheaper than OEM
                e46 m3 rotors are cheaper than even the friction disks on 2 piece rotors, let alone the initial investment in EXPENSIVE bbk rotors
                list goes on for plus's...
                no need for SUPER BBK kits, unless you are REALLY REALLY abusing your brakes
                  Cal, do you know the stock mounting center for the 2 holes for caliper mounting on the stock m3 spindles? Are they 3" apart?
                    what measurement are you looking for.. I have the stock calipers sitting on a shelf in my garage....
                      Stock Porsche 996tt pads (which are HUGE) do not cover the entire possible swept area of the stock rotor. The Porsche rotors are heavy, but they absorb a ton of heat also.
                        The caliper mounting centers. The distance between the two mounting holes on the back of the caliper, or on the spindle
                          easy enough... get you the measurement tomorrow sometime...
                            I have a set of OEM E46 M3 brakes. PM me if interested.
                              the only thing we would need off the e46 setup would be the oem rotors, and thats just if you were going with the wilwood kit
                                IT would be REALLY nice to find a caliper that would sweep the full 100% of the rotor surface......
