Yep, there are a bunch o Superlite cali's. The problem will be that you will need new ss lines up front, your current ones are not plug n play, then you will need an 90 deg fitting that screws into the cali and the ss line goes to that. the biggest issue is the fact that the superlights do not bolt right up to factory holes. The UUC kit comes with an adapter piece. YOU WILL NEED THIS. If you have CAD experience, you can draw your own and have a machine shop cut it. It you want to give it a try,
the wilwood #'s are 120 747 R
120 747 L
These can be purchased from http://www.hrpworld.com/index.cfm?
Hoerr Racing Parts
These guys are freakin great guys! The guy who started this co is Irv Hoerr. He was a Trans-Am and IMSA champ several times and a all around great guy. They are close family friends. His son in law Jason is the guy to talk to. He currently runs the place. Their # is 866-851-race.
If you cannot find a place to do the bracket, I could take off mine and see if I can get some turned out here in Chicago. If others are interested, I could see if we could get a kit put together. I prolly could get the calipers cheaper if there were several wanting this setup.
BTW: the BMW Motorsport 2 piece rotors are
#34112282801
#34112282802
i have a potential source for these too I can check into if anyone wants to go that route.
Pete
120 747 L
Hoerr Racing Parts
#34112282801
#34112282802
Pete
