Speaking of brakes I'm doing f/r pads & rotors on a 318. I'll call when I finish
School me on BMW/Porsche brake upgrade options.
Omg it's been so hectic today...... Sooo the verdict is: unless you find a 840/850 being parted out( privately, or junk yard) you are not finding these. ... I'm told inventory is waiting for the next big order....
Is that for used or new?
Pretty sure you can still go through realoem or pelican to get them new, but that's if you want to spend over 1k each caliper, which I would think is completely not worth it when compared to available big break kits made for the car.
Exactly. Spot on! ....... Btw that's $751 brand new
E46 ///M3 spindles have the same mounting center as e36 ///M3 ones.
http://www.m3forum.net/m3forum/showthread.php?t=301193
Found some used zcp calipers/rotors/and brackets on a junked m3 with zcp package with 49k at the local recycler. Got all 6 pieces for under 500 bucks out the door.
CSL brakes, here I come.
Not a multi-piston caliper but for now, ill take it.
wow... for $500 you have increased weight with a single floating caliper still
wned:
then please explain to me what you THINK the benefit of these calipers will be over your stock e36 m3 calipers?
good luck, cuz there are not any benefits over what you already have
That's quite a bold accusation coming from the same person who recommended me to use a package that completely wastes 30% of the effective rotor contact surface.
My current stock setup, AND the CSL one use the full 100% of the rotor. Why in the world would someone even make a package that doesn't even use the full rotor? To me that's simply, ridiculous.
Thanks, but no thanks. Nothing personal, not trying to be a d!ck either. Just my $0.02
fortunately, pad contact is not all that matters when you are figuring out braking effeciency... thanks, but try again :thumbsup2:
I'm sure it's not. But it's not all about weight either. The advantage of having a 30% bigger contact patch to use for braking is going to outweigh the loss of the extra pound or 2 from the csl calipers. I'm just not worried about gaining a pound or two; its not going to make a huge difference to me.
My thoughts on braking efficiency:
When you replaced your stock rotors with the euro drilled ones and threw on a caliper the only uses 70% of the rotor, you actually downgraded.
Your OEM rotors were only 315mm wide vs. the 325mm e46 EURO ones. Your stock calipers were using 100% of the stock rotor. With the euro/wilwoods this 10mm increase in size is completely wasted and nullified because you're not even making pad contact to the inside 30% of the rotor with the Wilwood caliper.
With a Wilwood Jimmyrig package you realistically have less braking torque than a stock e36 m3 rotor.
Falmesuit: ON
http://cache.gawker.com/assets/images/kotaku/2009/01/flame_suit.jpg
:takecover
