DIY: E36 budget SQ stereo-system installation
    The budget started out as less than $1000 - and it looks like I am going to be able to conform - barely. For a while there, I was expecting that I could do it for under $750, but that changed with the addition of nice cables and discrete amplification. The $1000 budget includes all of the materials necessary to do a quality (but not show-quality) installation in my 1995 M3.
    There is a related thread to this one (http://www.m3forum.net/m3forum/showthread.php?t=348799), where I asked for, and received, some great advice from other members before making purchase. I really recommend asking the advice those with experience before purchasing - while I thought I knew what I was going to buy, I am glad that I asked because some very good ideas were brought up and, in some cases, I changed my mind.
    What is my experience level?: Well, I've been doing my own basic stereo upgrades for almost 20 years (deck, speakers, amp, sub), and at one time competed in IASCA in Washington State while I was in the military. I apprenticed at a car stereo shop for about a year because I thought it is what I wanted to do when I got out of the military (and I got to make an employee purchase!). I am so glad that I did so, because I found out that it was not how I want to make my living. Am I great? No way. Am I good --- well, I can impress those that don't know much. I have only done custom fiberglass fabrication once as well as helping others on different occasions - and I remember some of the techniques. I have also been doing some reading up on the internet about new techniques for DIY fabrication. Most importantly, I understand 12 volt electronics and amp loading. I recommend before anybody embarks on a stereo in their car to research the basics and be very comfortable about wiring; you can destroy some very expensive equipment very quickly if you don't know what you're doing.
    Here is the plan, and I start today --- hopefully I can get some pictures up shortly.
    Equipment:
    Clarion CZ500 (bluetooth/ipod/hd radio) head unit: $149.99 (http://www.clarion.com/us/en/products/2010/audio/source_units/cd/CZ500/us-en-product-pf_1259392953332.html)
    NOTE: This is already installed and will not be part of this DIY. In fact, this is the reason for the stereo upgrade --- I thought that changing the source unit was going to be enough for me - but the truth is, it just made it worse. I can play my iPod now, but it sounds like absolute crap (likely because of the 15 year old speakers and double amplification).
    Soundstream RUB5.800 5ch amplifier: $225.08 (http://soundstream.com/AudioProducts/Amplifiers/rubicon.htm)
    Soundstream RBC.6 6.5" Component speaker system: $68.43 (http://soundstream.com/AudioProducts/Components/rubicon.htm)
    Soundstream Reference RW12 Subwoofer: $80.20 (http://soundstream.com/AudioProducts/Subwoofers/reference.htm)
    Clarion MCD360 (3-way active crossover): $82.07
    Boss 4ga amp installation kit: $24.39 (http://www.bossaudio.com/main/746)
    Raptor 100ft 14ga speaker wire: $29.00
    Monster MPC I204 5 meter 4ch RCA: $27.39
    3 sets of Monster I300MKII-1M RCA: $29.97
    Total Equipment cost - but $700 (note: all of this stuff was either on sale or last year's model on Amazon.com)
    ... add $100 at Lowe's for supplies to do the kickpanels.
    ... add $30 for misc fabric and other goodies.
    ... add $15 for grille cloth and other accessories from parts express.
    Installation design:
    Goals: Simple, stealth, lightweight, and that which cannot be lightweight should be easily removable at the track (sub enclosure). This is a track car and daily driver - I MUST not lose that focus!
    Front Speakers: The Soundstream separates are going to be run off discrete channels so that I don't have to use the passive crossovers. I was conflicted about how to do the speakers in the kickpanels:
    Simple (off-axis): This would be easy --- and it has been done quite a bit. A great example is here: http://www.diymobileaudio.com/forum/diyma-member-build-logs/42353-little-sq-install-e36-m3.html Unfortunately, this off-axis installation will definitely impact the staging.
    More fabrication (on-Axis): This is a LOT more work - but will definitely give much better results for staging. http://www.diymobileaudio.com/forum/diyma-member-build-logs/85513-quick-simple-job-e36-m3-sedan.html
    I have chosen to go the on-axis route. Additionally, I am going to put the tweeters in the kick panels as well. Nearly $100 in supplies from the local fabric store, Lowe's and Michael's --- more than the separates themselves cost.
    Amplifier / Processor: Not really clear on where this is going yet. Considered mounting it upside down under the rear desk, or maybe even right-side up with an air gap and fans. Regardless, I need to be able to access the controls on the end cap, so that may dictate the installation location more than I want. Since quick removal of the amplifier is not feasible - the installation will need to be done with light weight materials.
    Rear Speakers: Removing them.
    Sub: This is going to be the fun part. The sub will work well in a bandpass enclosure of about .75 cu.ft. per chamber netting a gain of about 3.4db on a range of 29-80Hz. Getting the ports aligned with the stock rear speaker locations is definitely a goal --- but I don't really know the feasibility of this yet while still making the enclosure removable. I have some ideas in mind, but they are too unrefined to try to explain them.
    Other: I picked up some "Peel and Seal" from Lowe's and will be deadening panels with this stuff instead of the expensive Dynamat. I have heard mixed reviews, but for $16 it was worth a shot.
    Pics coming soon.
    Finally getting er done eh? Hope to see many pictures!:goodluck:
      FYI: The Soundstream and Clarion links aren't working (for me at least).
      Looks like a great project.
        Sub'd
        Good Luck!
          Thanks --- fixed the links.
            Part 1: Fabrication of the kickpanel pods for the Soundstream separates.
            Recessing the speakers into the baffle. Note the very cool tool for the router allowing me to cut perfect circles.
            http://www.mydinanm3.com/images/stereo/DSCN0732.JPG
            Finished cutting the 6.5" holes.
            http://www.mydinanm3.com/images/stereo/DSCN0733.JPG
            Making sure the speakers fit good 'n snug before wasting time cutting the rest out.
            http://mydinanm3.com/images/stereo/DSCN0734.JPG
            Leaving a 7/8" border around the speakers for grille to attach. (Probably overkill - but I have seen issues with this being too narrow and the grille not have enough meat to stay in tact after being kicked a few times.)
            http://mydinanm3.com/images/stereo/DSCN0735.JPG
            The finished baffle.
            http://mydinanm3.com/images/stereo/DSCN0736.JPG
            Cut a 1/2 plywood piece the same size that will be used as the grille. Clamped them together to sand them to be the exact same size.
            http://mydinanm3.com/images/stereo/DSCN0737.JPG
            Stapled 1-3/4" wide matt board around the perimeter to allow the grill to be recessed fit when finished. Also left a small lip on the bottom to give the dowel's something to lean against.
            http://mydinanm3.com/images/stereo/DSCN0738.JPG
            The passenger side preliminary fitment.
            http://mydinanm3.com/images/stereo/DSCN0739.JPG
            The driver's side preliminary fitment.
            http://mydinanm3.com/images/stereo/DSCN0741.JPG
            Waiting for the superglue to dry on the initial dowel placements - after that I can mock them up inside the car to make sure the angle is correct and that clutch still has plenty of room.
              As I had expected, those preliminary fitments were not going to work. What I had to do was to dremel into kickpanel to recess the entire baffle assembly more. This reduces the protrusion [into the cabin] by about 2" and not only gives more room for the clutch, but it also looks much better.
              I am very excited about the angle I was able to get on the baffle and think that it will do exactly what is necessary to give a nice sound stage.
              Currently I am waiting for the adhesive to dry so that the baffle is secure on the kickpanel before beginning the cloth stretching. Here is how I am leaving the project for the evening:
              Test fitment of the passenger side kickpanel:
              http://www.mydinanm3.com/images/stereo/DSCN0743.JPG
              Both of the kickpanels after test fitement. Adhesive in place so that hopefully I can stretch cloth tomorrow morning and make more progress than I did today.
              http://www.mydinanm3.com/images/stereo/DSCN0745.JPG
                I understand the work involved with this... but I cannot stand how much this type of modification ruins the interior.
                Meh.
                  Many of us customize our cars, whether through colors and options or aftermarket mods, that do not suit others. I certainly would not miss the cheap plastic factory grilles down in the footwell, and added an aftermarket headunit to my own E36M3. I think the OP appears to have a good skillset for audio installations and look forward to seeing how it turns out in the end.
                    Meh.
                    I certainly understand your concern about affecting the appearance of the stock interior, I had reservations myself. For me, it came down to priorities - descent sound on my long commute -or- maintaining the stock appearance of an already modified 16 year old car. I chose the former.
                    I hope when I finish the kick panels that the visual impact is less significant than the audible impact.
                      Woke up this morning excited to be mixing some fiberglass resin --- but to my dismay it is raining. And there is no way in hell I'm going to mix that nasty stuff in my garage.
                      I stretched the cloth over the panels (love the leopard print) ... and as soon as I can go outside I'll get the first coat on. In the mean time I might run cabling in the car --- we'll see.
                      I did discover that the grilles are going to have to be sanded just a little to get them to fit in the grille area now that the cloth is wrapped. Duh, right? Well, I did think that the matt board would flex enough to account for the material; well, it didn't. Sanding will be easier and less risky than trying to cram them in there.
                      http://www.mydinanm3.com/images/stereo/DSCN0748.JPG
                        Meh.
                        That's how I was on my e36 m3. Never did anything because I wanted it to have a stock look. Looking back on it now, I wish I went all out with satellite radio and bluetooth and custom kick panels.
                          I think your picture hosting is down
                            Thx, fixed it. Bandwidth limitation kicked in.
                              wait leopard print what
                              are you completely getting rid of the dead pedal on a track car???
                              cant tell if trolling
