Z3M MSS50 DTC 155
    Z3M MSS50 DTC 155
    Hi everyone,
    After several low battery voltage / weak start issues, I’m now getting the following fault on my BMW with MSS50:
    DTC 155 – MSS50 Control Module Fault Memory Master
    The car still runs, but the fault keeps coming back.
    I’m thinking about trying a WinKFP ECU update in case the software got corrupted because of the voltage drops.
    Has anyone here already had this issue?
    Did a software update fix it, or did it end up being a hardware/power supply/DME issue?
    Thanks in advance for any feedback.
    Hi,
    I've already had this problem and it is a hardware issue (cpu issue from my point of view).
    https://www.youtube.com/channel/UCwN...zf45mXp6PDOCzA
      Thanks for your feedback.
      So from your experience, do you think the DME/ECU needs to be completely replaced, or is there still a chance to repair it (CPU repair/rework)?
      I’m trying to understand if it’s usually recoverable before looking for another MSS50 unit.
        I would try to replace the master cpu then if it doesn't work I would buy another one. Be careful with companies which "repair" this issue. They only disable dtc in the software which not solves the root cause of the problem.
