Why did my exhaust gaskets live <34k miles?
    Talking about the gaskets between the headers and the cat section. Replaced both at 95k miles and they started leaking again before 129k.
    Any thoughts on why? If it's possibly my fault, I'd love to know so I can be more careful this time.
    2
    Install error
    50.00%
    Both defective
    50.00%
    These things just suck
    50.00%
    2008 M3 Sedan 6MT
    2012 Mazda5 6MT
    Koni Special Active, Volvo parts
    Didn't see this was the e9x section nvm
      What's the cat section? Cats are in the headers on these cars.
      The primary cats are at the very front of the center section:
      Click image for larger version  Name:	RealOEM E9x M3 exhaust center section.png Views:	0 Size:	172.8 KB ID:	130978
      The gaskets in question are #3 in that pic.
      The headers themselves are just tubes.
      2008 M3 Sedan 6MT
      2012 Mazda5 6MT
        As long as you installed them correctly, they should not fail after 35k. What indication is there that they are leaking? TIS says to replace those self-locking nuts and torque to 27NM.
          My suspicions exactly.
          Car sounded louder than normal and sometimes ran a slightly rough. Got under it when it was cold, had someone start the engine, stuck my hands near the flanges, and felt a slight breeze around each flange.
          When I first replaced these gaskets, I definitely replaced all the hardware and I’m pretty sure I torqued everything to spec. Maybe I did a worse job than I had thought.
          2008 M3 Sedan 6MT
          2012 Mazda5 6MT
            It does not sound like it. Are both sides leaking and are these factory pipes?
              Yes and yes.
              2008 M3 Sedan 6MT
              2012 Mazda5 6MT
                First thing I'd do is check the torque. Maybe you forgot to torque them or something.
                Another possibility is that the gasket mating surfaces were not completely clean and caused a bad seal.
                  Have you removed the mid section since you installed the new gaskets? I usually consider them one time use.
                  Also I like to torque the right side first with the fixed flanged, that would pull the xpipe closer to the headers, then tighten the left side with the movable flange. I've had better luck since I started doing that.
                    One-time-use is my understanding as well. I have no record or memory of pulling the cat section since installing the gaskets.
                    I did have to pull the muffler section for something fairly recently. Maybe we didn't quite support the cat section enough and ended up tweaking the flanges at the headers or something? That's all I got.
                    Nice. Thanks for the tip.
                    2008 M3 Sedan 6MT
                    2012 Mazda5 6MT
                      Always replace the hardware with those donut gaskets. At least replace the lock nuts. If you tighten the fasteners improperly, you'll get a hot spot on the gasket and it will blow out a section of the gasket. Then the gasket just comes apart.
                        A-ha. There’s a plausible hypothesis.
                        I did use new fasteners and thought I had torqued them to spec, but I guess it’s worth a second look. Thanks for weighing in.
                        2008 M3 Sedan 6MT
                        2012 Mazda5 6MT
                          FWIW: turns out my engine mounts were shot and there were holes in the exhaust between the primary and secondary cats. We think the excess engine movement plus year-round-DD-in-the-northeast rust might have accelerated the failures, and I wrongly attributed (most of) the excess exhaust leaks to the donut gaskets.
                          2008 M3 Sedan 6MT
                          2012 Mazda5 6MT
