MSS6x Flasher - Now released!
  • 1984M3
    Thanks again terra! For now, just updated ecu software to 241E. Verified the before and after using your application. Will take a full read later on.
  • MSSAddict
    I got a response from bimmergeek by email
    If it helps someone who receives their cable,
    Martyn Thanks to you too who helped me on Facebook,
    terra Thank you so much for helping our little community
  • MSSAddict
    terra Hi✌️
    thank You very Much 🙏
  • terra
    If your car was built before September 2009 it shouldn't matter. If it was built after that, communications will work in one position and won't work in the other position. So pick the one it works with.
    Or if you have a multimeter, check the continuity between pins 7 and 8. You'll want the position where there is no continuity.
  • MSSAddict
    Sorry for my english 😅
  • MSSAddict
    Hello everyone,
    I received my bimmergeek cable, there is a button behind it, we can press it in high or low position, is it the right position to flash my MSS60 and MSS65 please?
  • Flaco
    The limiter brings up a good point tho. Is there a way to make the soft limiter a hard limiter? Hate the way it just retards timing / closes throttle as redline approaches. Much rather have fuel cutoff.
  • omhl
    What hardware are you running that 8600rpm is beneficial?
    this is primary a R&D thread... i don't think it has to be beneficial just to justify doing testing or trying things out.
    That being said e92 m3 has a soft limiter. It is easier to see if this soft limiter by setting a higher rpm vs one thats too close to stock.
    That way its easier to see if the changes i make to other mappings is fixes the issue or not.
  • Obioban
    Originally posted by omhl View Post
    So I went to the dyno today but it seems like the RPM is redlines at 8300. Even though I modified it to 8600. I checked with ECUWorx tool to see if I did it correctly in tunerpro and it shows up as 8600rpm.
    Is this because the RPM limiter is outside of the tune parameters and lives in the Program portion of it?
  • Flaco
    I wonder if your tuner figured out how to block reads then. I must have done a hundred reads on 160E without issue.
    Confirmed. Flashed back to stock and was able to read full and tune. Flashed tune again and got the same 'something went wrong' error.
  • omhl
    I also want to mention that I lifted the temperature RPM limiter as well to 8600. So thats not the issue.
    I'm doing a full bin pull and see what addresses are actually being written by the Tune button. Maybe its something else.
    On the mapping side of things:
    I see a few tables with 8300 8300 8300.
    And also some like 8300 7800 7600 7400 7200 7000. I'm suspecting that its coming from a standing limiter when front wheel speed sensor shows 0.
    Probably looking for a 8x1 table similar to the 8x1 RPM PER Gear Table. Since N+7 gears for DCT.
    UPDATE: yeah all the calibrations got written correctly. wonder if im missing something for dyno limiter.
  • dpaul
    No, RPM limit tables are within the calibration (0da) data. There must be some other problem. Maybe Martyn can comment
  • terra
    I did see a few places where there seemed to be a hard coded rpm limit, but it also seemed like said limit was at 9k RPM
  • omhl
  • terra
    Originally posted by dpaul View Post
    ALL OF THE ABOVE SAID, casual inspection of the flasher code does not reveal a reason why 200E program version should not be acceptable, although I could have missed it.
    If you were able to get a full read, what step did you try that failed? What error message do you get?
    The only thing I could think of is if he is not actually on 200E, which would mean that using the ZIF to determine the current program version isn't reliable (I figured it would be since WinKFP uses that for the check).
