Very respectable plan. Seems any project like this requires people with different skills sets, it's a shame that those guys don't want to contribute back. Are they saying that there were no program modifications made either??
I can see that the DCT computer only needs some inputs and outputs, because it truly acts as a blackbox. I don't have a M3 or a DCT, just an M5 6MT and M5 SMG. We know that there is a usecase where the DME really doesn't need to know that much about the engine when it's mated to the 6MT.
The BDM lock is only on the MSS60 right? I thought I read that the MSS65 doesn't have the BDM lock, there's not that much out there about the MSS65 vs the MMS60
MSS6x Flasher - Now released!
Honestly I haven't been messing with actual tuning yet. Right now my main goal has been to analyze the read/write routines and the various security mechanisms on the DME. To that end, a lot of my work has been disassembling the DME software, mostly the second stage boot code, in things like IDA and Ghidra. Also generally logged what all the commands flying around during a WinKFP flash were and things like that.Originally posted by hansbrix View Post
I agree all the more reason why we need to figure this out though. What are you guys using to view the bin? I'm assuming you're not using a conventional hex editor? Still new to the BMW/ Siemens stuff, but really want to learn more. I have winOLS installed but my experience with calibration work is on GM PCMs using the HP tuners, which is basically a complete IDE for editing the cal.
My next personal goal is to disable the BDM lock on the DME so that 1) we can recover these things if we mess up while OBD flashing (not very likely when limiting yourself to tune modifications, but once you start making program modifications the chance of error increases), and 2) so that we can clone DMEs in the case one needs to be replaced for hardware failure
I agree all the more reason why we need to figure this out though. What are you guys using to view the bin? I'm assuming you're not using a conventional hex editor? Still new to the BMW/ Siemens stuff, but really want to learn more. I have winOLS installed but my experience with calibration work is on GM PCMs using the HP tuners, which is basically a complete IDE for editing the cal.Originally posted by terra View PostYeah I dunno. They don't seem like assholes like Gintani, but I just have a very hard time believing that you can essentially plug everything in and just have it work without having to do any software manipulation on either the DME, EGS, or both.
Joined just to follow this thread! Can't wait to try it in my '11 e90 m3!
I’ve been through and compared the latest euro and latest US cars DME software and like Terra says the differences are very minor.
Don't even need to flash, I can extract the relevant stuff from the WinKFP files themselves. I wouldn't think there'd be a huge difference though.
On the other hand, perhaps there's a reason the Euro version has a much higher software number (520E) vs US (160E)
So given the new news on the m5board, I was wonder what you guys think about how can we figure out if the code to control the DCT/DKG is indeed there? Couldn’t we just use WinKFP to flash a MSS65 DME with a euro calibration then evaluate the difference in the code? I have a bimmergeeks cable coming but I have a few running M5s I could play with. I just have never flashed or updated modules yet on the M5 since I’m been busy fixing the myriad of mechanical stuff. I’m gonna try installing ISTA/P also since I think that plus an ICOM is require to update the I level of the car. But for the DME only, is it that I can use WinKFP with the appropriate datens to flash the DME. I suppose if someone already has the full bin of a euro DME we can just use terra’s nifty tool here? We’d have to edit the VIN and other stuff though right?
So at some point I accidentally introduced a bug that skipped over the signature check when flashing a tune to the MSS60. Fixed version is uploaded now, I recommend all testers redownload.
The one-stop electronics is probably one of the easier ones to modify. It already has AVR ISP header on board, so you don't need to do any soldering. Just plug in the programmer and program the chip
Just to confirm that the Frieling iflash adapter that comes with most after market tunes, will not work with Ediabas (inpa/ncs/ista/etc) software, therefore doesn't work with this flasher.
I've read conflicting info on that before, but tested it myself with no success.
I'm buying a bimmergeek cable vs modifying my old one-stop-electronic cable I've had for years.Last edited by tdott; 04-17-2020, 09:40 AM.
Sorry for the delay. Got so many PMs that I missed a couple. Responded to you
5MB is correct. It's structured like soOriginally posted by hansbrix View PostQuick question in how big a full read bin should be for a MSS65. My full read was 5.00 MB (5,242,880 bytes). Does this seem correct? I ask because a few months back I was looking at doing some tuning and found a bin that someone uploaded, I think it was a BDM read. That one was 1.00 MB (1,048,576 bytes). What accounts for the stark difference and what should be the correct size of a full bin?
Injection (left) Internal flash - 512KB
Injection (left) External flash - 2MB
Ignition (right) Internal flash - 512KB
Ignition (right) External Flash - 2MB
The tune is stored in the last 64K of each internal flash. Program code is spread between the internal and external flashes. Most of the external flash is empty, but is still necessary to make a full backup and to generate an RSA patch.
The bin you found was likely a dump of both internal flashes.
