Yeah I've written modified programs with no issue. RSA bypass needs to be done first
MSS60 Research
This similar to SBOOT on newer ECUs?Originally posted by terra View PostThat resistor to boot from external SRAM could be useful for recovering complete bricks.
Documentation and tools about Simos18 SBOOT (Supplier Bootloader), including a Seed/Key bypass and Tricore boot password recovery tool. - bri3d/Simos18_SBOOT
pshoey Do you know what version of SP-DATEN had the 080E? I have a half BDM read of one, but no full OBD read. Want to flash an mss60 with it from WinKFP and do some testing on it.Originally posted by pshoey View Postterra do you remember what OCD Speed setting you used with your Wiggler?
Also, seems my 5KW9586 ECU is BDM locked. I borrowed a Yanhua ACDP adapter that can read out either side - worked perfectly on my MSS65 but on the MSS60s I have, works on right side (obviously) but not on left side.
Interestingly, on 2 of the later ECU units, the error on the left side was CPU Encrypted but on the 9586 the error was "wrong model" (related to cpu identity).
I have one unit left to try, a 5KW9588 with 080E version of software. I'll open it up tomorrow if I get time.
It would seem to me that the "BDM lock" was introduced by a software update, given that the lock is software activated - I know you (@terra) disagree with that general opinion.
Got it. Well unfortunately I think this is a scenario.
Basically I was messing with the censorship states on my MSS65 which by default has its UC3FCFIG as 00000000 instead of 20410000. The clear censor operation requires being able to do an interlock write, which with IWS 0 means writing to the main UC3F array. And if that's in a censored state, the DME is stuck. And interestingly this seems to have also made it that I can't even trigger an erase or write while the DME is operating. So this thing is basically stuck in stasis.
The reference manual glosses over it, but freescale's extra documentation does support this.
Oh well. Maybe I'll try to take a crack at replacing the CPU. Good thing I don't actually depend on this thing for anything and I still have my MSS60
But on that note, I can confirm I have been able to clear censorship mode using the USBJtag NT device. Just need that IWS bit to be set to 15 if erasing the censor registers while in censored mode. I'll write that up and some scripts soon
