Originally posted by hobbit382
View Post
EWS delete testing
Do you have/ know how to use a hex editor?Originally posted by pshoey View PostI have an M3 and some spare MSS60s - what would be the steps to test this?
Also, can we have one post with all the info - for MSS60 and MSS65 ? would save people paging through many posts.
I can edit the original post once it’s verified
Yes, hex edit is no problem
I just want to make sure I a) don't fuck up my M3 and b) test the right steps so that I'm contributing useful test data.
Mainly want I need to know is what do I need to take from my existing DME (that does have a tune) for the new DME? Does EWS delete mean I don't need to do anything other than plug in the DME and it should just start?
Thanks for checking though !!
P.Last edited by pshoey; 08-28-2021, 01:24 PM.
gotcha.Originally posted by pshoey View PostYes, hex edit is no problem
P.
Just edit the bin at the address listed (verify your on 241e) flash the dme and check if it starts. If it does not, pull a ram read for me. If it does start, check to see what faults it has if any.
were you able to test it yet?Originally posted by pshoey View PostYes, hex edit is no problem
P.
Are you trying to do this on the factory dme? I thought you had a spare mss60?Originally posted by pshoey View PostNot yet - i have to remove the tune first - and of course the tune software had expired so I now that i have a new version - i can put the car back to stock, probably tonight and then try the patch.
correct. Having the stock dme, would probably start no matter. Use one of your spares and see if it will start.Originally posted by pshoey View PostI do have several spare MSS60 ECUs - so just to be clear (sorry for appearing dumb here!!) you want me to patch one of my spare MSS60s units, then install in vehicle and see if she starts and what codes might be logged?
It works!! Flashed a spare ECU with the 1 byte change and she fired up right away.
Only DME code I see is 2792 DME: Power management, vehicle electrical system but I think that was previously logged in the ECU as the mileage reported is much much greater than the car mileage.
Seems you got it - great work.Last edited by pshoey; 09-02-2021, 05:47 PM.
sweet! Thanks for testing.Originally posted by pshoey View PostIt works!! Flashed a spare ECU with the 1 byte change and she fired up right away.
I’ll update the original post for everyone.
Originally posted by hobbit382 View PostI’ve been working on ews delete for everyone, but don’t always have a car available to test on. If anyone has a spare dme and would like to do some testing change byte 0x65387 from 03 to 01 and report back.
update: tested and confirmed
Mss60 241E
(Confirmed)
Mss65 160E
change address 0x60FBC from 40 82 to 48 00 (confirmed)
MSS65 520E
change address 0x62DA8 from 40 82 to 48 00 (this software version is still untested but should be the same, if anyone test and confirms let me know so I can remove it)
special thanks to Terra, for all the hard work he has put into this flasher and everything else!
hobbit382
https://www.instagram.com/tv/CTVDyiq...dium=copy_link
I tested both the 160E version and the 520E version
And Software Version 520E works perfectly
thank youOriginally posted by MSSAddict View Post
hobbit382
Congratulations hobbit382 and thanks for sharing. You find it very quickly. Very impressive !Originally posted by hobbit382 View PostI’ve been working on ews delete for everyone, but don’t always have a car available to test on. If anyone has a spare dme and would like to do some testing change byte 0x65387 from 03 to 01 and report back.
Mss60 241E
(Confirmed)
Mss65 160E
MSS65 520E
change address 0x62DA8 from 40 82 to 48 00 (confirmed)
