Check for tuning / CVN checksum
    Hi - I've acquired a M3 and I want to check if it's got a tune installed or not, what is the easiest way? I have access to INPA, Protool, Tool32 and a K+CAN cable available. Ideally I'd like to (from google searching) run a Mode $09 check which should return a CVN value right? What would indicate it's a tune and what should that value be?
    It's an 08 M3 so MSS60. Cheers
    Tool32, load SGBD MSS60
    left scroll down to STATUS_CHECKSUMMEN_INJ and press F5
    in the right window you will see the result
    post here:
    STAT_CRC32_PROG_CARB_NV (Programm-CRC fuer Mode 9)
    STAT_CRC32_DATA_CARB_NV (DATEN-CRC fuer Mode 9)
    STAT_K_SK_CRC32 (CRC32-Aktivierung)
    Do the same for
    STATUS_CHECKSUMMEN_IGN
    ​I will give You the answer tuned or not
      You can also INPA use to get CRCs:
      Press Shift-F1 and post screenshot.
      Do the same Shift-F2
        On the MSS60, I wouldn’t rely on a generic Mode $09 CVN check alone. Mode $09 can return CAL ID/CVN where supported, but the important part is comparing what the DME reports against the correct factory software/calibration for that exact car. (Car Diagnostics Platform⁠)
        Since you already have Tool32 and ProTool, I’d first pull the MSS60 identification/software numbers and compare the installed software against the BMW factory ZUSB/software version. A CVN mismatch can indicate modified calibration, but a matching CVN by itself isn’t absolute proof that the ECU is untouched.
        If you want to go further, make a full read of the MSS60 and compare the binary against the appropriate stock file. The MSS6x Flasher tools specifically support MSS60 identification and full reads, so that gives you a much more definitive answer than guessing from the CVN alone. (github.com⁠)
        If you post the MSS60 identification/software numbers you get from Tool32, someone should be able to tell you what factory software version you’re on and whether it looks stock.
