Brain Fart: 87 Octane
    I had a brain fart the other day and filled the car with half 87 octane and half 91 octane (the highest you usually get in California). I blame these currently high gas prices! Since when is $4.15 a gallon the going rate for 87 octane?!
    Anyways, should I put in some octane booster? Just drive it all out at moderate speed on the free way without ever really getting into the revs?
    01 M5 Dinan S-2 ish
    03 M3 Dinan S-2 ish
    Nothing wrong with putting 87 octane but higher fuel octane is better. I’ve done it once or twice before, doesn’t affect the car in any way. Just drive until you need to fill up again.
      The S54 has knock sensors, so the ECU should back off timing/ignition if it hears knock coming from low octane fuel.
        Just use half the tank, and fill up with 91 or 93 again. You should be fine.
          Stock ecu 100% correct. But there are some shitty tunes out there that effectively disable the knock sensors (*cough* Evolve *cough*). So be careful if you are running a tune for a specific octane.
            Just don't hit VTEC and you should be fine
              Buy some Exxon Mobil stocks and you feel much better when gas price going up
                lol on the stocks. It's got the Dinan tune so hopefully they left the knock sensors in.
                01 M5 Dinan S-2 ish
                03 M3 Dinan S-2 ish
                  Dinan should be solid
