What Else Should I Change When I do My Clutch?
  • COVID-19
    +1 my brass one looked like Kaivs after 20k miles.
  • mrgizmo04
    On metal pin, IF you are going with metal, def don't do brass, do steel.
  • kaiv
    Flywheel is just a waste of money, if your current clutch hasn’t been slipping.
    Not necessarily. You just have to check for slop to decide whether to replace.
    I would also recommend the clutch fork and throwout bearing guide.
  • kaiv
    Originally posted by rbg View Post
    I'd get brass
    Don't.
    There's a reason the factory pin #21511223281 is steel
  • Obioban
    Flywheel is just a waste of money, if your current clutch hasn’t been slipping. The original fly wheel is good for 2-3 clutches, so long as it hasn’t been scored.
    I wouldn’t do detent springs, either— they don’t seem to go bad like on other cars.
    Metal pivot pins add nhv. If that’s worth it is up to you. Personally I’d replace with new plastic— failure is pretty rare. If you do go with a metal one, I’d use the OE BMW metal one.
    I’d do:
    new plastic pivot pin
    new OE throw out bearing
    new pilot bearing
    rear main seal
    clutch/pressure plate
    guibo
    center support bearing
    any exhaust nuts removed
    any exhaust gasket removed
    IF your trans is leaking, replace seals that are leaking. Our trans seems to be pretty leak resistant, so I’d skip replacing it if not.
  • Feffman
    I remember getting confused a few months ago as I found a thread or two in the old forum proclaiming/showing that metal pins do also deform in a worse way and that the original nylon's the way to go. Never followed up to try figure out what was what, and now all those posts are gone.
    When the ZF 5-speed transmission swap was done on my car, I inquired with my mechanic about installing the brass pin. He doesn't care for them as the brass can deform. We went with the Rogue Engineering stainless steel pin:
    Feff
  • mrgizmo04
    Are you talking about part number 23117512866? Damn that's an expensive part lol. Will also be getting an AutoSolutions SSK. Very excited about that.
    Yes, that one. It gets quite a bit of wear from the fork sliding back and forth, so worth replacing.
  • heinzboehmer
    Originally posted by HDdave View Post
    Maybe the guibo? Otherwise it seems like you have got the list covered pretty well. You may want to consider replacing your dual mass flywheel.. I did my conversion at 151k and went ahead and did the flywheel. The new one did have a substantial amount less play.. I don’t think I would mess with the other seals unless necessary though.
    Yeah I was thinking about doing the flywheel too. Did you go for the Luk one?
    Outside of getting a new fork, make sure to also get the sleeve/guide that goes over the tranny input shaft, it also gets gouges.
  • mrgizmo04
    Without the bellhousing there you have a bit more access to cpv. Might be worth to replace the flywheel, even of the surface might look ok, there could be some play from dual masses. Your driveshaft will be partially out, so you can do guibo/csb, tranny mounts. Front tranny seal is not bad at all, rear is a bit more work due to the big nut. Outside of getting a new fork, make sure to also get the sleeve/guide that goes over the tranny input shaft, it also gets gouges. Do all detents with springs and guides, there should be about 7. I got a metal pivot pin, seemed to make more sense to have metal on metal with fork vs plastic. All the bushings in shifter will tighten everything up very nicely. You could also get a different shifter now. Rear main - be VERY careful with, you don't want to do it again, definitely use the plastic inner cup it comes with. Chance to replace starter if you want, slave cylinder, etc.
  • HDdave
  • rbg
    I'd get brass
  • ATB88
    Right. Planning on replacing the pivot pin and release arm as well. What's the consensus on metal pins? I'm a bit wary to use one as it won't deform and might damage other parts in situations where a plastic one wouldn't.
  • heinzboehmer
    Make sure you replace that fork pivot pin and maybe use a metal one.
  • rbg
  • What Else Should I Change When I do My Clutch?
    I'm getting ready change out the clutch in my car. Plan on replacing it with the Luk kit and using OE throw out and pilot bearings. Since the trans will be out of the car, I plan on replacing all detent springs, rear main seal, driveshaft centering sleeve, and shifter bushings.
    I was thinking of doing the seals for the input, output, and selector shafts, but my recent experience installing a new front crankshaft seal is making me want to stay away from radial seals. My trans has no leaks and so it seems replacing these seals isn't necessary. My car has 122k on it so should I replace them anyway?
    Is there anything else I should do with the trans off? Thanks!
    Edit: This is the list of things I ended up ordering for myself. I left a couple of things out (some shifter bushings, exhaust gaskets, etc) because I either already had them or they were included as part of the aftermarket pieces I bought.
    Item Part Number Quantity Unit Price Total Price Vendor
    Luk Clutch Kit - 1 $269.29 $269.29 Amazon
    Pressure Plate Screws 21207548052 6 $1.52 $9.12 FCP
    Throw Out Bearing Guide Tube 23117512866 1 $65.78 $65.78 ECS
    Throw Out Bearing 21511223582 1 $73.77 $73.77 FCP
    Pilot Bearing 11211720310 1 $26.40 $26.40 FCP
    Steel Pivot Pin 21511223281 1 $23.92 $23.92 FCP
    Release Arm 21511223302 1 $30.72 $30.72 FCP
    Locking Pin 23111222979 1 $20.05 $20.05 ECS
    Locking Pin 23311224130 1 $17.06 $17.06 ECS
    Ball 7119986280 1 $0.99 $0.99 ECS
    Locking Pin 23317501584 1 $39.29 $39.29 ECS
    Thrust Pin 23311282444 1 $27.16 $27.16 ECS
    Compression Spring 23311228393 1 $7.04 $7.04 FCP
    Compression Spring 23111222720 1 $8.77 $8.77 FCP
    Compression Spring 23317511337 1 $9.55 $9.55 FCP
    Compression Spring 23311228405 1 $9.32 $9.32 FCP
    Repair Kit 23317506947 1 $186.24 $186.24 ECS
    Flywheel 21212229900 1 $383.34 $383.34 FCP
    Flywheel Bolts 11222243051 8 $2.39 $19.12 FCP
    Rear Main Seal 11142247867 1 $122.45 $122.45 FCP
    Input Shaft Seal 23121228493 1 $14.43 $14.43 FCP
    Output Shaft Seal 23121222769 1 $5.32 $5.32 FCP
    Shift Selector Seal 23127501582 1 $22.12 $22.12 FCP
    Driveshaft Centering Sleeve 26117526611 1 $9.25 $9.25 FCP
    Guibo 26112226527 1 $68.78 $68.78 FCP
    Guibo Nuts 26127536563 6 $1.63 $9.78 FCP
    Exhaust Gasket 11627830668 2 $14.43 $28.86 FCP
    Exhaust Nut 18301317898 4 $6.35 $25.40 FCP
    Exhaust Nut 11621744323 6 $3.07 $18.42 FCP
    Shifter Arm Bushing 25111222015 1 $18.61 $18.61 FCP
    Autosolutions AutoCross - 1 $540.00 $540.00 AutoSolutions
