which head gasket should i use?
  • SteelGreyM
    I used a cosmetic gasket in my recent rebuild. As far as thickness your machine shop should easily be able to figure this one out.
  • Zekarus
    yeah seems you are right. machine shop just got the block and head separately to machine both and bore the block. he just recommended to use a thicker gasket if possible. is it enough to check the clearance with kneat and a correct timed motor? waiting four weeks is right now not an option or i'm going to use the athena gasket. first complete motor overhaul for me. 😅
  • stash1
    Originally posted by Zekarus View Post
    Staying NA and yeah right thanks that's an option too. PTV should be okay according to the cam spec sheet I guess?
    Click image for larger version  Name:	PXL_20210505_225327953.jpg Views:	0 Size:	81.3 KB ID:	103173
    I believe that the spec sheet is just pointing out the recommended PTV clearance...I'm assuming that either you and/or the machine shop checked that during assembly?
  • Zekarus
  • stash1
    hi guys. i'm rebuilding my motor and got today the block and head back. 0,2mm where removed on the head and 0,1mm on the block. so all together 0,3mm. std head gasket is 0,64mm and cometic has 0,91 and 1,02mm head gaskets. and a four week delivery time . i also have new JE 87,5mm pistons and dbilas 288/280 cams - 12,75/12,5mm. and i got an Athena cut ring gasket in hand which is 1,2mm thick. soooo what should I do?
    Are you staying NA or going FI? If you're staying NA, why not just go w/a factory (Elring) headgasket, and enjoy a slight compression bump...assuming your PTV clearance is ok.
  • Zekarus
    started a topic which head gasket should i use?
