Originally posted by GyroF-16
Key fob replacement
Would you mind pointing me to where you found the instructions for programming the remote unlock function for the key?
Originally posted by GyroF-16 View PostThis thread got my hopes up, so I shopped online as Maxima SE described.
But all I found was this:
https://www.thebmwminipartstore.com/...VsdHMmYT1ibXcm bz1tMyZ5PTIwMDUmdD1iYXNlJmU9My0ybC1sNi1nYXM%3D
$577.70 doesn’t excite me. Where are these $160-200 keys?
66-12-6-955-748
Thank you - I just couldn’t find that.
Would you mind pointing me to where you found the instructions for programming the remote unlock function for the key?2005 Phoenix Yellow M3 Coupe 6spd
2007 Imola Red Z4M Coupe
its in a pic in the link i posted.
Having read it, now I have an additional question. It sounds like the “initialization” process must be done with all keys, and says “Always initialize the keys in the same order”. It also references rolling codes. But the initialization process involves pressing the key buttons. One of my original keys has a dead battery (won’t charge while being used). Do I really need to “initialize” ALL my keys in order to add one? That would lead me to believe that the “dead” one would no longer work. Or are the “rolling codes” mentioned only for the unlock feature, and not for the car to recognize and accept the key to allow starting the car (as I understood it to work in my E36).
Also- my E46 didn’t come to me with the miniature key (all black, all plastic). I have them for all my other cars, and appreciate them as “emergency backup” keys, kept stashed in a safe place in case I lose my primary key while away from home.
Anybody know where I can order one of these plastic keys? Or the part number for such a thing?Last edited by GyroF-16; 05-16-2021, 07:16 AM.
Ah- thanks again. It’s much easier to make out on my iPad vs iPhone.
The "rolling code" is for anti-theft feature between the key/EWS/DME only, nothing to do with the remote control features.
You use a working key to initiate the remote function program process, then program ALL other keys, one after the other, during this programming period.
EWS is effectively a challenge response which it does with changing codes. The rolling code part of EWS is between the EWS and the DME.
$577.70 doesn’t excite me. Where are these $160-200 keys?2003.5 Titanium Silver / Black 6M/T (Gone)
