So my rear subframe mounts have the cavity foam in them but I found a crack on one mount while prepping for my vince bar. Would it be possible to still weld the crack? Do I just spot weld it essentially and not let too much heat into the metal?
Welding After Foam
Welding After Foam
Journal: https://nam3forum.com/forums/forum/m...grey-speed-runTags: None
I am using the epoxy kit. There is a crack I have to weld up first though.Originally posted by Rkymtnrider View PostOr use the epoxy kit?
I ended up just doing a very small area at a time and letting it cool down after every few millimeters. Also had a fire extinguisher ready to go.Originally posted by bigjae46 View PostI think you’ll set the foam on fire. Maybe test it and have someone on stand by with a fire extinguisher?
Check the foam SDS which should have more info.
Sent from my iPhone using Tapatalk2003.5 E46 M3 Silver Grey/Cinnamon
Good deal. I wonder if that weakens the reinforcement from the foam. I know it does in composite sandwich structures.Originally posted by Sid_E46 View Post
I do have plates and a vince bar now so it should be fine.Originally posted by bigjae46 View Post
